78 seriers troopy mech noise
Submitted: Saturday, Feb 27, 2010 at 15:45
Member - brett g (VIC)
Hey all was after some feed back on troopy noise two weeks in to a full trip done some heavy towing in hills ,Now if i take off from on a
hill when the clutch disengages under full load so to speak i have a err noise like a dry bearing , the clutch is not slipping as i have tested it 5th gear handbrake on and went to take off revs dropped and stalled just as it stalled same noise happen .Thrust bearing ok as no noise when you put your foot on off clutch pedal, all oil levels ok and no slipping in drive belts . Also can anyone recommend a good mech in Tumut area.
Brett.
Reply By: Member - Alastair D (NSW) - Saturday, Feb 27, 2010 at 15:58
Brett,
Not sure if the 78 series is similar to the 75, but such a noise can from the clutch master cylinder vacuum assist if there is a leak or fault.
Have a look at the clutch master cylinder. If there is a vertical shaft with a flat plate on the bottom, at the end of the horizontal cylinder then you have a unit with vacuum assist. I will take a picture tomorrow and post it. Check if there is any fluid leak on the bottom of the plate. If so then it needs a repair kit from Mr Toyota.
alastair
406345
Follow Up By: Member - brett g (VIC) - Saturday, Feb 27, 2010 at 16:14
Thanks Alastair ,
I have had a look no fluid leak dusty dry it also is the master cylinder with out booster.
Brett
676051
Reply By: Member - Dave and Shaz - Sunday, Feb 28, 2010 at 16:11
We have a Troopy and there's a great mechanic in
Jindabyne if you are near enough to there. Don't know of any in Tumut. He works at the Shell
Servo just at the Alpine Way turnoff. Did a great service for us and picked up a tie rod about to pull, something our (ex) mechanic of 30 years forgot to do in the "big trip" checkup
406519
Follow Up By: Member - brett g (VIC) - Sunday, Feb 28, 2010 at 21:04
Thanks for that Dave and Shaz ,
I have been recommended some one in Tumut by a local would of been handy to know about the problem when i was in eucumbene thanks again for your reply.
cheers Brett
676322
Reply By: get outmore - Sunday, Feb 28, 2010 at 22:50
TD troopy or an N/A one
the gearbox in the NA troopies really isnt up to heavy towing
406590
