Valvoline engine oil equivelant for GU 4.2 turbo...........
Submitted: Saturday, Feb 27, 2010 at 17:09
Michael ( Moss Vale NSW)
Gday all, I'm looking for a Valvoline equivalent engine oil fro 2003 GU 4.2.. The Nissan specs say API CC CD CE CF or CF-4.. All i can find that is close and readily available is API CH-4/SJ. Is this ok to use?? thanks in anticipation. Michael
Reply By: Michael ( Moss Vale NSW) - Saturday, Feb 27, 2010 at 17:10
Opps!! Sorry about the "Equivalent" Typo!!
406355
Reply By: Member - Graham H (QLD) - Saturday, Feb 27, 2010 at 18:03
Dont know about your GU but Croozers have similar specs and I use Penrite HPR15 Diesel
406366
Follow Up By: Old Dave - Saturday, Feb 27, 2010 at 18:56
Penrite is not Valvoline.
dave
676082
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 27, 2010 at 19:05
Dont you think I realise that.
I was offering an alternative oil that meets the spec as it seems from the post
that there is no Valvoline that does.
A bit surprising I thought.
676084
Reply By: Member - Amy G (QLD) - Saturday, Feb 27, 2010 at 20:44
http://www.driverstechnology.co.uk/oils.htm is a useful link regarding the different oil specs. It says that CH4 has superceded CD, CE, CF, etc and can be used with both high and low sulphur diesel.
As long as the oil is the correct weight it will be fine.
406389
Reply By: Michael ( Moss Vale NSW) - Saturday, Feb 27, 2010 at 20:58
Thank you to all who replied. I will look at the Penrite grade and Amy, the site is good reading for all who know not a lot about oil, such as myself.. Ch4 is fine for my Patrol. regards, Michael
406394
Follow Up By: Member - Wayne B (NSW) - Saturday, Feb 27, 2010 at 22:00
Hey Mike any old sump oil will do. Anything better would be like feeding strawberries to pigs. Complete wast of time.
Seriously you will be ok with Ch4. The newer engines don,t have the
fuel dilution problem of the older engines as there is very little over fueling these days. Many of the detergents that use to be in Diesel Oil are no longer needed.
Wayne
676122
Reply By: Member - Allan F (Gold Coast) - Sunday, Feb 28, 2010 at 09:28
Reply By: kiwicol1 - Sunday, Feb 28, 2010 at 16:53
Have been using valvoline in my diesal GQ, it has now done 380,000ks and uses no oil at all, and motor has never been touched. I did once change to castrol oil but it started using oil so went back to valvoline and had no problems since.
Cheers Col
406529
Reply By: Alloy c/t - Sunday, Feb 28, 2010 at 16:58
Valvoline Super Diesel will fit the specs.
406530
Reply By: Michael ( Moss Vale NSW) - Sunday, Feb 28, 2010 at 19:40
Thanks Everyone!! i will use the Super Diesel from Valvoline.. regards Michael
406550
