Anderson Plug problem
Submitted: Saturday, Feb 27, 2010 at 20:21
Lynnie
Hubby had to remove the car battery today to put it on charge......no probs there but after re-connecting everything and starting the car he's noticed that the Anderson switch in the engine is now glowing red.
Obviously something is amiss but we can't work it out.....common sense tells us somehow it's turned on or off? - but we can't work out what to do??
If any one can help we we would be most grateful?
If it's something very simple we are...er he, is going to be very red faced.
Here is the thing that is glowing red:
Reply By: _gmd_pps - Saturday, Feb 27, 2010 at 20:38
sounds like you have a short somewhere which discharged the battery
and now since it is recharged it does the same thing again and does glow the
switch until battery is discharged. sounds like a shotty job with little to no fuse at least not sufficient fusing.
Can burn the car though.
Take the battery off first and check the short with an Ohms meter.
good luck
gmd
406387
Follow Up By: Jedo_03 - Saturday, Feb 27, 2010 at 21:03
Hmmm...
Well... I just wonder from the wording of the OP whether Lynnie and Hubby would have a clue about Ohms meters and checking for shorts...
If they did - then they'd have already DONE that... Hey..??
Lynnie - You have a Problem...
Something in your battery/electrical system is short-circuiting... Is why the plug is glowing RED... Is heating up like an electric fire... And shouldn't be doing that...
FIRST - Disconnect the battery...
THEN - Tell us WHY you have an Anderson Plug in the Engine Bay...
AND...
What is connected to the wire on the OTHER end of the Anderson Plug...
Plenty of people here to talk you through it...
But DISCONNECT the battery...
Jedo
676101
Follow Up By: Lynnie - Saturday, Feb 27, 2010 at 21:36
Hi Jedo.....you're right we are novices.
First up what we have in the engine is'nt the actual Anderson Plug (thats in the cabin under the steering wheel) but whats in the engine is probably the isolator?
I have taken a pic but can't upload it as we're not members.
Poor hubby is now concerned that he's done something wrong and wants to disconnect the battery again as you suggested.
Nothing is ever easy is it?
LOL
676108
Follow Up By: Lynnie - Saturday, Feb 27, 2010 at 21:42
I can hear you all laughing now.....and I'm loosing it I tell ya!
Of course the Anderson plug isn't in the cabin! It's at the back of the vehicle...not under the steering wheel.....strewth it's been a long day!
676112
Follow Up By: Peter Horne [Krakka] - Sunday, Feb 28, 2010 at 09:38
Hi Lynnie, don't worry about laughing, at least your car hasn't burnt to the ground. Nothing to laugh at then!!!!!!!!!
Cheers.
676189
Reply By: Member - Toyocrusa (NSW) - Saturday, Feb 27, 2010 at 20:53
Hi. I'm guessing you mean the anderson switch has a light in it to indicate when it is in the on position. If that is the case check at the anderson plug and see if it is "live". Check if both power or earth are live. If it is earth he may have put the wires back on the battery incorrectly. Bob.
406390
Reply By: ABR - SIDEWINDER - Saturday, Feb 27, 2010 at 20:54
Could it be the battery isolator that is doing what it should.
The RED light shows it is working.
Have you got a photo ?
Anderson plugs do not have red lights.
Derek
406392
Reply By: Lynnie - Saturday, Feb 27, 2010 at 21:18
Sorry but I can't put a pic on as I'm not a member....shall fix that soon enough.
I think Derek was right about it being an isolator...my mistake calling it a 'switch'
Hubby swears he's never seen it glow red before but i did mention that he's never looked at it in the dark beofre either?
It makes sense that it would be lit up when it is 'on'...just need some peace of mind that all is
well and that he hasn't wired the battery incorrectly...he was super careful.
Lynnie
406398
Follow Up By: Bonz (Vic) - Saturday, Feb 27, 2010 at 21:52
Here's the pic
676118
Follow Up By: Crackles - Saturday, Feb 27, 2010 at 21:56
"Sorry but I can't put a pic on as I'm not a member"
You don't need to be a member to post a photo. Just upload it a web site like Photobucket, copy the link, then click on "Insert Image" (below) & paste the image address in there.
A little bit of mucking around but makes it easy for everyone to know what you are talking about & get a better answer to your problem.
Cheers Craig..............
676120
Follow Up By: Lynnie - Saturday, Feb 27, 2010 at 22:00
Many thanks Bonz for putting the pic up for me.
The flash made it difficult to see the red light but it is inside a clear plastic cover and you can see it just under the thick red wire (looks pink).
Hubby has disconnected the battery again until we know that the car isn't going to blow up on us.
Thanks for help and advice so far guys....
676123
Follow Up By: Bonz (Vic) - Saturday, Feb 27, 2010 at 22:03
All is good Lynnie, thats just the LED indicating that the isolator is switched in. It would have always been there just easier to see at night.
Connect the battery back up and relax.
676127
Reply By: ModSquad - Saturday, Feb 27, 2010 at 21:57
We have added a pic into the inital post for this thread as per a request to help the fault finding. Lynnie, you should be able to add in a pic, it may be just a little more complicated thats all. Anyways this ones done for you! Hope you get the answer you need.
The Squad of Mod
406408
Follow Up By: Lynnie - Saturday, Feb 27, 2010 at 22:16
May I just say a huge thankyou to Bonz, Derek, Jedo and all the other
forum members for their help and advice to this pair of 'mechanically challenged' idiots......we are very much in your debt and hubby will rest easy tonight.....right after he puts the battery back in....heehee!
Oh what fun we are going to have when we leave in 8 weeks.....I can see it now....two
grey heads stuck under the bonnet on some far flung dusty track in the middle of nowhere...
well maybe not nowhere as I wont let him go too far off road....Lord knows what trouble we'd get into.
So once again thank you for a job
well done guys....
Lynnie
676135
Reply By: Von Helga - Saturday, Feb 27, 2010 at 22:28
Lynnie,
Did you or your husband either fit or have fitted a Redarc battery isolator. If so google it and try to ascertain what model it is as that looks like what you have from the photo and then read the WWW site for indication of what the
little red light means. I assume that is what you meant to say when you were talking about the "Anderson Switch glowing".
Trevor
406416
Reply By: Doncow - Sunday, Feb 28, 2010 at 09:56
If you have just charged the battery the voltage will be up, and of course the red light will be on until the voltage falls again!
406461
Reply By: Member - Charlie M (SA) - Sunday, Feb 28, 2010 at 20:00
Hi Lynnie
Is the brown wire going to another accessory or is it going to the red light box, as it maybe the active wire to activate isolater manualy, and if that is the case if car started and automatic closed isolator with enought volt it would stay on even when engine shut down as it has activated isolater with power from battery.
Charlie
406555
Follow Up By: Member - Charlie M (SA) - Sunday, Feb 28, 2010 at 20:03
Usually the other wire is to manually activate the isolator from a switch
Charlie
676297
Reply By: Michael ( Moss Vale NSW) - Sunday, Feb 28, 2010 at 20:07
How did you load the original pic if you cant load pics.... Im confused!! Michael
406556
Follow Up By: Maîneÿ . . .- Sunday, Feb 28, 2010 at 20:18
Michael,
The "Squad of Mod" added the pic into the inital post for this thread *as per a request* to help with the fault finding.
They are really good little Mod elves :-)
Maîneÿ . . .
676304
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Feb 28, 2010 at 20:39
Mainy, Thanks, i missed that,, I was more interested in the problem.. Michael
676313
