2-stroke in diesel a myth??
Submitted: Thursday, Mar 04, 2010 at 09:49
ThreadID: 76538 Views:7285 Replies:13 FollowUps:25
I was getting a small job done this morning- by a well known & well respected diesel shop here.
I mentioned and asked if 2-stroke in diesel has any effect.
His comment was that he could see no poitive benefit, more than likely negative effects.
It may glug up the fuel filter, and if 2-stroke is miscible with diesel fuel, could even glug up the pump and/or injectors !!!
Reply By: Andrew & Jen - Thursday, Mar 04, 2010 at 10:24
Did a similar thing earlier this week - asked one of Adelaide's top diesel injector / pump specialists. His recommendation was to use one of the many additives around as they not only did what the 2 stroke oil would do, but much in addition. I have been using Chemtech Diesel Power for 10 years in the boat and found it very good - no water in the filter, clean injectors, no algae in the tank - so I will now start using it in the recently acquired (old - 95) 4WD.
AnswerID: 407210
Reply By: Gazal Champion - Thursday, Mar 04, 2010 at 10:38
Hi Signman, I told my injector specialist, well respected in our area, that I was now using 2 stroke in the diesel to improve the lubrication effect, and he did not advise me not to, in fact he suggested running a liter of petrol through it once in a while to give it a clean out.
Now I have been previously advised that that is a definite No No!
Its a bit like climate change I think. If you dont like what you are being told, ask someone else till you hear what you want to hear I guess. I have no opinion either way regards 2 stroke, but having read so much on these pages and elsewhere with regard to 2 stroke, and personal experience, just having spent $3400 getting my injectors and pump reconditioned after only 270,000 Ks it makes you feel you should be doing something to stop the wear.
The wear in the injector pump was excessive and that is why it cost $2000 for its repair. It had to have a new body and some of the internals were buggered.
Just my observations with my somewhat limited experience although I might say I have a D4 dozer and a diesel tractor as well as trucks and a backhoe and another smaller dozer, so the experience is not that limited.
Regards, Bruce
AnswerID: 407214
Follow Up By: Member - Serendipity(WA) - Thursday, Mar 04, 2010 at 20:00
Hi Bruce
I once had a diesel injector place suggest that some unleaded petrol now and then in the diesel would 'clean out the system'.
I tried it with my old HJ75.Well it certainly improved the power. Went much better.
Unfortunately I burnt out 2 glow plugs. I thought that might be just a coincidence so some 6 months later I tried it again. Burnt out another glow plug.
I think adding even 1 litre to a full tank of diesel is just too much. I think the fuel burn was too hot and heavens knows what else happened inside the combustion chamber.
I stopped doing it.
David
FollowupID: 677179
Follow Up By: Member - Tour Boy ( Bundy QLD) - Thursday, Mar 04, 2010 at 20:51
I used to put 300ml of unleaded per tank (90lt) every second fill in all my 2H and 1HZ motors and they were smoother and quieter and had more power.
Never had any glow plug issues and I was living above the snow line at the time.
The biggest cause of premature glow plug failure is not letting them glow right up.
The landcruisers have a dual system, 1 for the light and 1 for the plugs.
If you turn on the ignition ignore the light, watch the volt gauge and listen for the click. Only after the click turn the motor over. If you go only by the light they will only half glow.
The plugs also stay on for around another 30 secs after starting at a reduced voltage (the click when the gauge comes up slightly).
The other thing is it is best to replace all the glow plugs at the same time don't mix and match.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 677189
Reply By: Member - Allan B (QLD) - Thursday, Mar 04, 2010 at 10:46
Did a Google search on 2-stroke oil in diesel and found a lot of forum hits but nothing from a reputable authoritative source such as an oil company or a lubrication engineer.
Seems to me that if it were as simple as adding some lubricant then an oil company manufacturing the diesel fuel would add it at manufacture then promote their product as superior to gain market share.
So I think I'll wait for a while before I start mixing cocktails in my fuel tank. This could be another Hi-Clone myth!
Had a chuckle at a comment on another forum...... "Use extra virgin olive oil myself. And every third tank I add the juice of seven lemons, a clove of garlic and touch of rosemary. Sweet!" LOL
AnswerID: 407216
Follow Up By: Gazal Champion - Thursday, Mar 04, 2010 at 11:18
Hi Allan, did the person on that other forum mention anything about people gathering around his exhaust pipe, LOL.
Interestingly, where I work we get through some cooking oil in the deep fryer and it is changed very regularly. My neighbor asked for a drum and so I gave him one and he filtered it out and was putting into his Massey Ferguson tractor. he said it made the world of difference to the sound of the motor. Made it run much quiete. I was convinced enough to add some to my tractor and was amazed at the difference. It immediately ran much quieter. That is why I was not suspicious when others said that oil in the diesel would lessen the wear factor.
Our mix rate was around 1 litre cooking oil to around 50 liters of diesel.
These machines will run on straight cooking oil though I am not advocating that.
Regards, Bruce
FollowupID: 677086
Follow Up By: Member - Allan B (QLD) - Thursday, Mar 04, 2010 at 11:54
Hi Bruce,
I note that a number of people have commented on quieter running. Is it possible that the combustion reaction rate is changed and thus reduces knocking which is the cause of most noise of a diesel engine?
FollowupID: 677091
Follow Up By: Member - joc45 (WA) - Thursday, Mar 04, 2010 at 14:31
I'm inclined to agree; the burn rate is probably changed. But as I understand it, the very fast burn rate of diesel in an engine is part of the reason for its high thermodynamic efficiency. Could this mean that the efficiency is reduced when the knock is reduced?
Re additional lubrication, diesel is itself a lubricant, and injector pumps would be designed around that fact. Rotary pumps, anyway, dunno what the new CRD pumps do...
FollowupID: 677118
Follow Up By: Member - Barry (NT) - Thursday, Mar 04, 2010 at 17:21
Agree with Allan B above
goes to the principle of heavy versus light oil (read fuel) and burn rate and revs
older diesels that ran on "gunk" years ago would strain under cylinder pressures with todyas diesel IMHO
FollowupID: 677157
Follow Up By: Member - mazcan - Thursday, Mar 04, 2010 at 19:02
hi all
last week after being so happy with the lower noise factor in my vw golf crd1.9diesel and smoothness
i decided to add 2st to my mazda bravo 1997 diesel and after only 100km's the has transpired it into a very quiet and smooth motor on start up and under harsh throttle cruising along it's hard to hear any diesel noise at all and it's not my imagination it's a fact
i have thought about this a lot and although i have no scientific facts imho i believe that the two stroke softens the detonation of the diesel in the cylinders hence the much quieter motor but i have also noted there is no reduction in power in my vehicle as was suggested by someone that this could happen
no one has forced me to add the 2st oil but im quiet happy with the notible results so far on both vehicles
so if you dont agree or want to follow suite well so be it as it's upto the individual owners
but i dont believe it's a mythe as one experienced diesel repairman stated as it's his own text book trained opinion and some one at some stage will break ranks and try something new
is'nt that how new systems are developed after all
but there is enough forum evidence out there and some with thousands of km;s of 2st usuage with no ill effects but then after all that's mho and everyman to his own liking
cheers and for what it's worth
FollowupID: 677171
Reply By: Member - Joe F (WA) - Thursday, Mar 04, 2010 at 12:56
G'day Everyone
Amaizing really, this business of putting in a little or a lot of anything into your Diesel tank that feeds the Diesel motor.
Rudolf Christian Karl Diesel ( 1858 - 1913 ) is known for inventing the DIESEL engine.
His diesel engine technology was designed to run on " Peanut oil ".
Here we are in the year 2010 with Biodiesel ~ and vegetable oils and used " Chip shop oil " successfully running modern diesel engines.
The major improvements in the diesel engine have been substantial, but mainly in electronic management and engine build materials ~ not so much in what it burns. There are now diesel technolgy engines that power aircraft and yes they burn either Diesel or Jet Fuel.
Anyway ~ Diesel is an oil byproduct derived from the refinement of petroleum.
AnswerID: 407226
Follow Up By: Member - Wayne B (NSW) - Thursday, Mar 04, 2010 at 22:46
QUOTE. Here we are in the year 2010 with Biodiesel ~ and vegetable oils and used " Chip shop oil " successfully running modern diesel engines....
No NO NO. Not in modern CDI Engines you don't. When the system comes to a grinding Holt, and it will, the manufacture will politely tell you to bugger off.
The old inline and rotary pumps are fine they will chew up anything.
Wayne B
FollowupID: 677210
Reply By: Member - Roachie (SA) - Thursday, Mar 04, 2010 at 13:00
Well, I've been using 2 stroke in my 6.5 litre Chev V8 diesel for about 8 months now and it has DEFINITELY made it run quieter and smoother. I would not continue to spend the $$ on it if I had any doubt about this at all (cos I am a tight rrrrrr-s!!!! hehehe).
That's all the proof I need.
Roachie
AnswerID: 407227
Reply By: Rock Ape - Thursday, Mar 04, 2010 at 14:11
Where I used to work they had 2 4000Hp Ruston midspeed diesel engines.
These engines ran 40lb boost, peanut cams and 4 valves per cylinder. They couldn't stop the valves hammering back into the heads and cured it by injecting metered amounts of 2 stroke oil into the system.
These were million dollar + engines and the modifications came from the manufacture.
Have a good one.
AnswerID: 407240
Follow Up By: fisho64 - Thursday, Mar 04, 2010 at 17:05
Seems somewhat odd that Ruston has been making diesels for donkeys years and only just started putting 2 stroke into them to cure the "valve problem"?
What was the cure previously?
FollowupID: 677153
Follow Up By: Member - Roachie (SA) - Thursday, Mar 04, 2010 at 17:30
Quote: "What was the cure previously?"
Answer: Probably 5000ppm sulphur content in the diesel. It is this lower sulphur content in diesel (50ppm now a days), that is causing issues with older diesel engines from what I have read. This was certainly the "cure" on my old fashioned Chev 6.5 V8.
Of course, it goes without saying (but I'll say it anyway) that the fuel companies will swear on a stack of bibles that their low-sulphur stuff won't hurt an engine........but then again, of course they'd say that, wouldn't they. Imagine the ramifications if they agreed that their crraappy product was causing expensive machines to fail or at least operate in a less-than-ideal manner.
Roachie
FollowupID: 677158
Follow Up By: Rock Ape - Thursday, Mar 04, 2010 at 17:49
Not odd at all, they moved into the next century, and this was a new high out put low weight diesel a few years back.
Note! 40lb boost on turbo and peanut cams as used in racing engines, high lift/long duration and slam shut very quickly.
FollowupID: 677161
Follow Up By: Member - Allan B (QLD) - Thursday, Mar 04, 2010 at 17:51
Roachie (and others), it's not the low sulphur content of the diesel that affects the lubrication. The problem is brought about during refining where removing the sulphur also causes removal of other components that provide lubrication. This is then addressed at the refinery by adding suitable lubricants.
FollowupID: 677162
Follow Up By: Member - Roachie (SA) - Thursday, Mar 04, 2010 at 18:05
Thanks Allan for that insight...... I wasn't sure "why" it happened....just aware that it "has" happened.
As I said in an earlier response..... I don't know if there's any scientific evidence about the benefits of adding 2 stroke to my diesel tanks, but it runs that much smoother that I will continue to use it.
Before i started using it, I honestly used to whince everytime I started the cold motor. It sounded like all the rockers were unbolted or something....banged and rattled terribly. It was okay after about 1 minute of idling.
Now, with the 2 stroke, it sounds okay right from the get-go. Also, whilst I don't expect it has anything to do with me using the 2 stroke, I have also noticed recently that oil pressure is present within 2 seconds of starting the engine....used to be about 5 seconds.
Roachie
FollowupID: 677165
Reply By: howesy - Thursday, Mar 04, 2010 at 15:24
Here's a good read, a study into addatives in diesel and it covers 2 stroke
http://www.johnfjensen.com/Diesel_fuel_additive_test.pdf
AnswerID: 407248
Follow Up By: howesy - Thursday, Mar 04, 2010 at 15:29
all be it marine 2 stroke oil
FollowupID: 677131
Follow Up By: Rockape - Friday, Mar 05, 2010 at 12:48
Howesy,
thanks for that, it is a very thorough test.
Have a good one
FollowupID: 677288
Reply By: Member - Allan B (QLD) - Thursday, Mar 04, 2010 at 17:41
OK, found something of interest on a Shell site.
"What is Shell Ultra Low Sulphur Diesel?
Shell Ultra Low Sulphur Diesel is a quality diesel fuel suitable for use in any vehicle that currently runs on regular diesel.
Shell Diesel has a high cetane number to help ensure smooth running and which assists starting at temperatures well below those prevailing in Australia. In addition the lubricity of the diesel fuel is controlled and monitored to help ensure that adequate lubricity is maintained to prevent fuel pump and fuel injector wear."
"Will my diesel engine require additional lubrication as a result of using a low sulphur fuel?
Sulphur content is linked to the lubricating properties of the fuel and some low sulphur fuels may require additives to provide lubrication to fuel pumps and injection systems.
Shell addresses this at the refining stage so you do not need to introduce additives into the fuel. Shell Diesel fuels will continue to be tested to ensure that they provide adequate lubrication."
As I expected, the issue of lubrication is being addressed at the refining stage.
I have worked in the petroleum refining industry and believe me, these companies go to a lot of trouble to produce a quality product. It is not in their interests to market a product which will harm the machinery of a consumer.
AnswerID: 407259
Reply By: Member - Phil G (SA) - Thursday, Mar 04, 2010 at 18:09
I could understand using the stuff if the power increased or the fuel consumption got better or the motor went for an extra 500,000k, but I'd be worried about adding anything that makes a diesel motor quieter.
AnswerID: 407261
Follow Up By: Member - Roachie (SA) - Thursday, Mar 04, 2010 at 18:22
Ah, Phil, you're just thinking back to the old days when you added a banana to your diff or gearbox before selling it, to quieten it down a bit...hahahaha
FollowupID: 677166
Reply By: Member - Oldplodder (QLD) - Thursday, Mar 04, 2010 at 18:20
Allan raises a good point.
Suppose that is why for the the couple of years after introduction of low sulphur diesel so many people with older model diesels had injection pump seals failing.
Lack of lubrication for that type of seal design.
And fuel companies where paying out towards to cost of the repairs (up to $500.00 from memory).
I missed out by about 3 months, since the subsidy only ran for about a year, starting about 6 months after the introduction of low sulphur diesel.
So, it is my assumption that older diesels may have some problems, but hopefully fixed with an overhaul to the pump if required. While new diesels are designed for low sulphur diesel.
Well, it is the reason in the first place for low sulphur diesel, to try and lower particle emissions.
New diesels now have common rail for a finer controlled injection, and some now have particle filters. With the old diesel fuel and injection systems, I assume the particle filters would clog up pretty quickly.
AnswerID: 407262
Follow Up By: Ranger75 - Thursday, Mar 04, 2010 at 21:15
John,
My background is 40 years as a Research Chemist in the oil industry.
Some of the comments above are not well informed including those from people claimining some association with the Refining of crude.
The issue you mention concerning leaking seals after the introduction of Low Sulphur distillate was caused by the Refining process removing an increased proportion of Naphthenic and Aromatic components from the end product along with the sulphur.
The lower level of these Aromatics/Naphthenics reminining in the fuel allowed the seals to shrink reducing the interference fit thus allowing leakage.
The oil companies responded by adding seal swell additive to the fuel.
The Sulphurised terpenes and naphthenes that were removed during the desulphurising process were in fact the significant antiwear compounds in the higher sulphur fuel of past years. These compounds decomposed at the interfeace of metal to metal contact in the pump surfaces creating active sulphur compounds that bound to the metal {Iron} surface creating a sacrificial Iron Sulphide type layer that was worn away preferentially therby reducing the amount of metal removed during operation.
As an example the same process is at work in differential oils interaction with the gear teeth.
Two stroke oil particularly low ash Marine two stroke [TCW 3 spec] has some very good active antiwear compounds, not quite of the calibre of the Sulphurised compounds in fuel and gear oil but nonetheless they do reduce the wear rate in the pump.
The best products to use are specially formulated for the reduction of extreme pressure wear as in fuel pumps. Products like Opti-Lube and Flashlube are typical.
FollowupID: 677197
Follow Up By: Member - Oldplodder (QLD) - Thursday, Mar 04, 2010 at 21:48
Thanks for that ranger,
useful to know.
FollowupID: 677203
Follow Up By: pop2jocem - Thursday, Mar 04, 2010 at 23:02
I wonder how a very small quantity of gear oil well mixed with diesel would go. Gear oil of course has additives to counter extreme pressures generated in applications such as differentials. Don't know what other nasties it's got that may damage a fuel injection pump. Personally I don't think I would put anything other than straight diesel in modern CRD systems though.
Cheers Pop
FollowupID: 677212
Follow Up By: Member - Allan B (QLD) - Friday, Mar 05, 2010 at 00:12
Ranger, thank goodness that someone with appropriate expertise has contributed.
Perhaps you could be more specific about your expression that "Some of the comments above are not well informed"
Are you able to comment as to why the oil companies do not introduce components equivalent to Opti-lube and Flashlube to the diesel at the production stage?
FollowupID: 677225
Reply By: zacc - Thursday, Mar 04, 2010 at 20:37
I have put 2 sroke in my work vehicle (diesel ) , it was quiter had more power down low and yes the economy improved.
Next tank did not put 2 stroke in , it sounded noisey again lost the power i gaine and economy went back to as before.
AnswerID: 407277
Reply By: pdm3006 - Thursday, Mar 04, 2010 at 22:24
Yep, as Ranger75said, outboard 2-stroke TCW-3 oil does add lubricity and make older diesels run more smoothly.
I use Gulf Western Outboard Motor Oil TCW-3 in my 1997 HZJ75 ute whenever I use diesel in it. At $25 per 5 litres, it's cheap to use. I try to use biodiesel as often as possible - B100 from Fina in Thomastown, Melbourne.
When using petrodiesel, I add 200:1 2-stroke to improve lubricity.
I haven't conducted controlled economy tests on the cruiser, but when running petrodiesel with 2-stroke, it seems to run very slightly more economically at 11.5 litres per 100km, without 2-stroke it seems to run at 12 litres per 100km. No noticeable difference to power or torque.
Cheers.
Peter.
AnswerID: 407290
Follow Up By: Member - Allan B (QLD) - Friday, Mar 05, 2010 at 00:05
Peter, I cannot see where Ranger said "make older diesels run more smoothly"
FollowupID: 677222
Follow Up By: pdm3006 - Friday, Mar 05, 2010 at 09:01
Sorry, that was my inference from improved lubricity.
However in my case at least, it does quieten down the injector pump and the engine is a little smoother - not that a 1HZ is rough/noisy in any case.
My Cruiser has done 407,000 km, still going strong and I'd like to keep it that way. It only costs me $2 per fill to add the 2-stroke oil and I think that's cheap insurance.
Peter.
FollowupID: 677247
Follow Up By: Member - Allan B (QLD) - Friday, Mar 05, 2010 at 09:36
Yes Peter, now that I have an opinion from an expert I think that I also will add TCW-3 to my 1HZ even though it's barely run-in at 250,000km! If I can locate them I may use Opti-lube or Flashlube as Ranger recommended but I bet they are more expensive than TCW-3.
Note however that Ranger only referred to reducing the wear rate in the pump, not the engine in general. Even so, prolonging the pump life could be a considerable saving.
For good measure I may even strap a magnet onto the fuel-line. LOL
FollowupID: 677255
Reply By: Member - Doug T (NT) - Thursday, Mar 04, 2010 at 22:24
After reading most of that I guess no one seems to realise diesel already has oil in it. so why add more,
AnswerID: 407291
Follow Up By: Member - Roachie (SA) - Thursday, Mar 04, 2010 at 22:31
Doug, here is a copy'n'paste from above....... (just for you). I can't make myself any clearer than this:
FollowupID: 677206
Follow Up By: Alloy c/t - Thursday, Mar 04, 2010 at 22:49
On a totally different tangent Doug , have you seen the photo of the croc shot a Boorolloola last week ,6.325m or in the old money 21 and a 1/2 foot long ,, i have trouble getting the photos up on here so if you want will email to you so you can post em up , bl----y one big lizard that chewed the prop of the boat !
FollowupID: 677211
