Isuzu D Max
Submitted: Thursday, Mar 04, 2010 at 21:21
ThreadID: 76554 Views:12366 Replies:6 FollowUps:5
Looking at buying a Isuzu D-max twin cab. Could owners give me their opinion on this vehicle please. We will be using it for towing a 20 ft caravan.
Reply By: D200Dug- Thursday, Mar 04, 2010 at 22:59
We have the 2008 holden Rodeo that is the identical DMax
We added new suspension as the standard is way to soft and sloppy and put in a DP chip + a few other mods and it is a really good unit, we have not picked up our van yet but we plan to tow a 19ft evernew once it is built.
e me at
silverimage at powerup.com.au
if you want more info
AnswerID: 407298
Reply By: westozal - Thursday, Mar 04, 2010 at 23:43
I have one...very happy so far. 2009 Sx dual cab, 4x4, canopy,bull bar etc.
35 mpg most tank fulls, 28 mpg half towing half solo. 5.8 m poptop van.
No problems so far but still only 3600kms so a bit soon to tell.
Tows well and is quite comfortable considering it is a commercial vehicle and base model.
Have no hesitation recommending the vehicle. Only point I would raise is that it is not as capable off road as my previous GU Patrol or 80 series were, but I am not full on offroading now so suits our purpose.
Oh the gear change is a bit average ...rubbery feel but you get used to it.
Regards Alan.
Use search , there are other posts on the Dmax.
AnswerID: 407306
Reply By: stumbly1 - Friday, Mar 05, 2010 at 09:57
We picked up our new D-max last week, we havn't towed our van with it yet but very happy with fit and finish.
Quite comfy for a work vehicle, we got the auto and are very happy with it - smooth changes and good ratio's.
as stated above, we will be doing some thing with the suspension, but would do that with just about any vehicle.
Could do with a bit better bottom end power, but that could be because its auto, a chip upgrade will fix that.
All up they seem to have a pretty good rep and Isuzu have been building reliable trucks for years.
Best of luck with what ever you choose.
Regards, keith
AnswerID: 407348
Follow Up By: stumbly1 - Monday, Mar 08, 2010 at 18:44
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule .
Forum Moderation Team
FollowupID: 677823
Reply By: Member - Malcolm (Townsville) - Sunday, Mar 07, 2010 at 10:49
Good one Turk
I had my first problem last week. The auto trans and MIL lights came on for no reason at all. Also found that I couldn't shift the auto trans lever from park without depressing the lock device. Called the RACQ and the guy couldn't find anything wrong. Drove it to the workshop in town and they reset the computer (a half day job !!) and said everything was OK. Time will tell.
3700km and climbing slowly LOL.
Malcolm
living the 'good life'
AnswerID: 407617
Reply By: Wayne & Gaby - Monday, Mar 08, 2010 at 10:47
G'day Turk,
We have a new auto LSU D-Max Crew Cab only 3,000 klms on it so far, have not towed yet but it was the only one in it's category that tows 3 ton with a auto gearbox. Be aware they are not the same as a Colorado, D-Max has DOHC with chain drive and 16 valves, Colorado has SOHC with belt drive and only 8 valves, from what I understand there are subtle differences throughout the whole vehicle. So if you want a real Isuzu buy the D-Max, it also has one more cross member on the ladder chassis then any other vehicle in it's category. The inside finish/fit out leaves a lot to be desired but we bought it for the specifications and reliability. We intend travelling around Australia towing a smaller van. I don't know where you live but don't be afraid to get a price from a smaller country dealer, my first price was from the Sunshine Coast dealer (I live near Gympie) then I rang the Bundaberg dealer (talk to Arthur) and saved $2,500 instantly.
All the best
Wayne
AnswerID: 407827
Follow Up By: malglo - Monday, Mar 22, 2010 at 18:54
"D-Max has DOHC with chain drive and 16 valves, Colorado has SOHC with belt drive and only 8 valves"
Where did you get this crap from, I hope not from a disohnest dealer - I thought this had been sorted out eons ago - RODEO RA7/8, COLORADO & D-MAX ALL HAVE THE 4JJ1 TWIN CAM 16 VALVE DIESEL MOTOR
mal
FollowupID: 679888
Follow Up By: Wayne & Gaby - Tuesday, Mar 23, 2010 at 10:26
Well Mal,
I suggest you do your research before you accuse someone of posting 'crap', below is a portion of the information found on the CarShowroom Website. There is no mention of DOHC's because it does not have them!!
The Holden website does not mention any of the below specs re their 3.0 lt Diesel in the Colorado because they know it is not the same as the Isuzu engine.
If you were to research first this then allows you to post CORRECT INFORMATION as I did, as opposed to the CRAP you have posted. By the way 'disohnest' is spelt DISHONEST.
Dec 01, 2009
COLORADO
CREW CAB P/UP
DIESEL TURBO F/INJ
4 SP AUTOMATIC
DIESEL TURBO F/INJ
Capacity 2,999 cc
Size 3.0L
Cylinders DT4
Valve Gear OVERHEAD VALVE
Bore 95.5x104.9
Max Power 120km @3600rpm
Max Torque 333Nm @1600rpm
Compression 18.3
No. of Valves 8
Have a good day
Wayne
FollowupID: 679959
Follow Up By: malglo - Wednesday, Mar 24, 2010 at 19:25
I have a RA7 Rodeo with the 4jj1 engine and 2 mates who own Colorado's, 1 of whom is a mechanic and he too is a bit over this continual misinformation originally started after an incorrect Holden sales brochure which some Isuzu dealers took advantage of. I personally was told the pushrod story by an Isuzu salesman and also at a later date another Isuzu salesman admitted to me that some funny business did go on.
From Redbook
2009 Holden Colorado LX RC
Engine
Engine Location Front
Configuration In-line
Engine Size (cc) 2999
Cam Double Overhead Cam
Engine Cycle 4 Stroke
Engine Type Piston
Engine Number 4JJ1TC ######
Engine Code 4JJ1TC
Cylinders 4
Valves per Cylinder 4
Compression Ratio 18.3
Power 120kW @ 3600rpm
Torque 360Nm @ 1800rpm
Induction System Turbo intercooled
Fuel Type Diesel
Fuel Tank Capacity (litres) 76
Fuel Delivery Multi-Point Injection
Method of Delivery Electronic Sequential
Carbon Dioxide (g/km) 228
Fuel Combined (l/100km) 8.5
You too have a nice day
mal
FollowupID: 680126
Follow Up By: Tonyfish#58 - Wednesday, Mar 24, 2010 at 19:44
My 2007 RA7 Rodeo also has the 4jj1 engine
FollowupID: 680129
Reply By: 3322poppy45 - Friday, Mar 19, 2010 at 12:45
G'day Turk,
We bought an LS-U D-Max auto a month ago and I am very happy with it, we are going to tow a 5th wheeler with it next year so I want to get it run in before then. Got a great deal from Blue Ribbon Motors at Yamanto, very friendly and helpful. I don't think you can go wrong with a D-Max.
AnswerID: 409473
