Attaching Hyland Hitch to C/T
Submitted: Wednesday, Mar 10, 2010 at 08:50
Member - Howard T (QLD)
Hi All
First of all I would like to thank all who gave advice on my purchase of a hitch for my C/T. Thread 76479.
I have chosen a Hyland Hitch and now have to attach to my C/T.
My trailer is a Trackabout and has 3 RHS arms that meet at the hitch point.
The hitch has 4 bolt holes which line up with the drawbar arms.
My question is-
Do I weld the hitch to the plate that is already attached to the top of the drawbar or
alternately do I weld a plate onto the underneath side of the drawbar and bolt thru the RHS and the bottom plate.
If I bolt through the RHS would it weaken the arm/metal strength as I do have some weight
on the drawbar including a spare tyre?
Any constructive comments would be appreciated.
Many thanks
Howard.
Reply By: Shaker - Wednesday, Mar 10, 2010 at 09:37
Your question is a little confusing.
If the hitch has bolt holes that line up, why wouldn't you just bolt it on, with the correct tensile strength bolts?
How was your old hitch fitted?
Is the Hyland hitch weldable?
Maybe a photo would help to understand better.
408194
Follow Up By: Member - Howard T (QLD) - Wednesday, Mar 10, 2010 at 10:11
Hi Shaker
Sorry for the confusion. Bolt holes actually line up with the drawbar (100mm box).
I would have to drill through the drawbar to attach hitch which I am reluctant to do as I feel it will affect the strength of the drawbar.
Old hitch was a normal 50mm ball hitch. This actually had the bolt holes in the middle of the hitch and not on each side as the hyland does.
Have just found out that the hitch is not weldable as it is cast.
At work at present. Will photo tonite if not resolved.
Howard
678127
Reply By: Baz&Pud (Tassie) - Wednesday, Mar 10, 2010 at 09:50
HT,
My understanding is by law that the hitches have to be bolted, you are no longer allowed to weld them.
Baz
408198
Reply By: Injected - Wednesday, Mar 10, 2010 at 10:20
Howard
If you need the tow hitch to be bolted underneath for height purposes, it should be fine as long as the plate is welded properly and the bolts are of the correct grade.
As for the weakening of the RHS would depend on the thickness of the RHS.
If you dont have height issues i would just bolt it to the top plate and use the correct grade bolts, and all should be good.
One thing i have found with the hyland hitch is if you are using a genuine prado tow bar tongue ( cast one) you will have to get a hayman reese style tongue as it wider or have a stainless steel plate made ( same diameter as the socket ) to go under your tow ball above the tongue. The wider tongue is required to keep the socket that goes over the ball flat and straight. If its a prado style tongue or an aluminium riser tongue the socket will flop backwards / forwards around when travelling.
Hope this helps
408201
Reply By: Wizard1 - Wednesday, Mar 10, 2010 at 11:15
If in doubt, take the trailer to a trailer manufacturer or engineering/welder and get them to weld on a new base plate with the correct holes.
408214
