pop top repairs
Submitted: Saturday, Mar 13, 2010 at 21:02
Glenn-Lee
Hi we pulled the roof off repaired the leaks and replaced the ceiling in the upper roof my question is how do we set up the scissors to get the roof back on. It needs adjusting as it did not sit right so cant use existing holes. any ideas would be much appreciated thank you. Glenn
Reply By: nomadoz - Sunday, Mar 14, 2010 at 00:39
Is it possible it is back to front?
408725
Follow Up By: Glenn-Lee - Sunday, Mar 14, 2010 at 08:46
thaks for that I have the old holes its the spring load thats awkward we will get there today is another day
678679
Reply By: Member - Teege (NSW) - Sunday, Mar 14, 2010 at 07:56
Glen-Lee
I had one put on my van by professional caravan repairers. It took 2 blokes about 30-40 minutes to get it right. I don't believe there is any easy way. From the Caravans Plus website:
".......it can take quite a lot of experimenting in position, which involves new holes being drilled each time as the opposing forces must be balanced to have correct location when up as
well as when down."
Good Luck
teege
408735
Follow Up By: Glenn-Lee - Sunday, Mar 14, 2010 at 08:47
thankyou Its the sping load thats awkward I will get it done with a bit of struggle thanks
678680
