Toyota 1HDT Engine
Anyone out there got any tech info on after market timing belt tensioner that does not loosen belt(causing belt to jump a tooth)should engine run backwards in a steep climb situation.I believe they exist.. Thanks John W
Reply By: Member - Andrew (WA) - Sunday, Mar 14, 2010 at 17:05
Sounds like a question for the LCOOL forum.
You'll get your answer there.
AnswerID: 408789
Reply By: pop2jocem - Sunday, Mar 14, 2010 at 19:13
aquilon, I would agree with Andrew about asking on the lcool forum. The only piece of info that I have that may or not be of help is that as far as I know the 1HDT engine has the same tensioner setup as the 1HZ. I have just gotten hold of a 1HD-FT to replace my 1HZ with and have found that they have a quite different belt tensioner and I'm sure that this design and method of function would not let the belt jump a tooth if the engine were to be run backwards. Whether this tensioner would fit the earlier 1HD-T I don't know but it may be worth checking out.
Cheers Pop
AnswerID: 408814
Follow Up By: fisho64 - Sunday, Mar 14, 2010 at 22:38
where did you get the the 1HD-FT and what did it cost? Definitely a good score!
FollowupID: 678821
Follow Up By: aquilon - Monday, Mar 15, 2010 at 04:45
The 1HDT has the same tensioner as the 1HZ , so if the 1HDFT set up fitted YOUR 1HZ it will fit my 1HDT..Thanks mate...John W
FollowupID: 678838
Follow Up By: pop2jocem - Monday, Mar 15, 2010 at 17:45
Sorry about not getting back sooner........house maintenance...YUK...
fisho... got mine from a local wrecker (Perth WA) just happened to be in the right place at the right time, he actually called me about a different matter.
It was in a late '97 80 series that was a statutory write off. Cost involved a bit of horse trading so actual dollars does not really mean much (if you get my drift)
aquilon, I'm not sure if I am reading you right (which is quite possible..lol) but I didn't mean that I was trying to fit the 1HD-FT tensioner to the 1HZ or vice versa
I am fitting the whole engine (1HD-FT) in place of the 1HZ engine. I had the timing belt cover off to check the condition of the belt and tensioner bearing. A sticker on the cover from a local Toyota dealer said that they had recently been changed but being both anally retentive and an untrusting old bastard I had to have a sticky beak. It was during my explorations that I noticed the 1HD-FT tensioner had a fluid filled spring tensioned system that would not let the belt jump no matter what direction the engine turned. Quite different to the 1HZ setup. As previously said I am not sure if this later one will fit either the 1HZ or your 1HD-T but if it does it may fix your concerns.
Good luck mate
Cheers Pop
FollowupID: 678931
Follow Up By: aquilon - Monday, Mar 15, 2010 at 20:34
Thanks mate .....John Willard
FollowupID: 678958
