winding mechanism 1985 jayco dove
Submitted: Monday, Mar 15, 2010 at 10:36
ThreadID: 76873 Views:16110 Replies:8 FollowUps:6
please help just purchased a 1985 jayco dove went to wind the top up fine came to wind the top down fine till it got to about 200mm to go and thats it - it worked once i got it down but every time i try it now it stops at 200mm
when you start to wind the handle anti clockwise you can feel the cable relax and start to go down but its as though its relaxed too quickly and could do with another couple of turns and it would be ok
really frustrated as managed to close once but not now
please suggest
Reply By: PradOz - Monday, Mar 15, 2010 at 11:33
Hi - it can be a number of things so would recommend you get an understanding of the winch and cable system first. Best way is to buy one of Trevor Eastmans Camper service manuals
They are clearly written and easy to understand. When you get the service manual keep it with the camper not at home. Nothing like getting a problem while on holidays and having the know how elsewhere.
As yours is an early model the cables tend to twist around each other more than the later ones. Best to look in behind the winch/winder by removing ply panels. Do not run your hand along any cables in there. They can be sharp and slice your hand open. Best to get the book first. It will help with your model. Good luck....
AnswerID: 408895
Follow Up By: maggie63 - Monday, Mar 15, 2010 at 11:38
thanks will look into getting book
FollowupID: 678878
Reply By: Hairs & Fysh (NSW) - Monday, Mar 15, 2010 at 11:38
If you can wind it up and place 4x 2x1 pine or similar pieces of timber, 1090mm if my memory serves my right, at each cnr to take the weight, then you might be able to pull the front area apart and have a look to see if something is catching. May even be in the rear section that something is stopping the it from retracting back into the full closed position.
Is it one cnr that stops coming down first? or is it all cnrs that stop at once?
May even be the cable crossing over itself on the ratchet/winch mechanism catching and not allowing it to fully retract.
Let us know how you go.
AnswerID: 408896
Follow Up By: maggie63 - Tuesday, Mar 16, 2010 at 11:36
re why i opened a new thread new to the site wasn't sure what to do - is that ok
FollowupID: 679031
Follow Up By: Hairs & Fysh (NSW) - Tuesday, Mar 16, 2010 at 19:40
Sure, Not a problem.
Just asked, that's all.
So
to the site.
I'm interested to know how you went. You asked how you go about removing the push up spring thing. Well you will have to chok the to top up with the 2x1 I mentioned above, then back the winder of a faction so all the weight is on the 4 pieces of 2x1. Then you will have to remove the ply paneling, move the 19mm box section out of the way so you can pull out the coiled/spring looking thing, make sure you don't loose the mushroom shaped bolt that pushes on the telescopic box section. Make sure that the coil thing slides freely and retracts all the way back into the 19mm box and doesn't snag on anything. It doesn't take much for it to get caught or by out of alignment.
I had to learn all about my 87 Swan by myself.
Once I had a cable break, the next time the pulley bracket bent9Rust) and the last time the 19mm sq tubing bent while winding the top up, one of us had forgotten to check all the latches,
. Isn't that a fun job with the top down with a storm brewing over head.
Anyway, I hope you get it sorted. BTW, don't use grease when lubricating things as you put it back together, Dust sticks to it, use a dry lube or silicone spray.
Have fun
FollowupID: 679086
Reply By: maggie63 - Monday, Mar 15, 2010 at 11:53
all corners come down together and stop together i will see if the cable has twisted but its difficult to get in to see the mechanism
thanks
AnswerID: 408899
Reply By: Nargun51 - Monday, Mar 15, 2010 at 12:09
The winding mechanism on Jayco campers is a real Heath Robinson affair with winches, wire ropes and pullies going everywhere
Simply put, the mechanism for the supports is a winch which is attached to a flexible rod into inside the support by metres of wire rope. As the wire is winched in the pulley arrangement shortens the length of the flexible rod against the base of the support, and the roof is pushed up.
Problems can exist because of damage to the plate that holds each of the ropes to each support to the winch, fraying of the wire ropes themselves, pulleys being damaged, the inability of the wire ropes to move freely, the flexible shaft being U/S or clogged up with grease or the supports themselves being damaged and jamming.
I think the Jayco site has a diagram of how the system works, but a Google search will also find links.
To determine the fault you are going to work along the system to work out where the issue is. The wires, pulleys and flexible rods are either found behind the front or end walls or in the ‘step’ in front of it. Wire rope also runs behind the kitchen.
Follow the path (wear thick gloves because frayed wire rope is sharp!). Clean or grease as required. The support poles themselves can be greased carefully with silicon grease.
Due to the number of components in the system, it is hard to give a definitive answer to your question. I’d suggest it is probably the flexible rods jamming or clogged up with grease or a screw, which happened to me
AnswerID: 408900
Follow Up By: maggie63 - Monday, Mar 15, 2010 at 12:24
thanks for that will check the wires and cables as you suggested
thanks
FollowupID: 678882
Reply By: Member -Pinko (NSW) - Monday, Mar 15, 2010 at 12:44
Hi Maggie
Since your jayco is a 1985 model methinks some or all the cables are shot.
I had a similar experience. The pullies located in the corners of the jayco were made from nylon and the cables eventually cut through to the locating bolt. This caused the cable strands to slowly snap and as they did so the broken strands build like birds nests at the pulley and will not allow the lid to come down.
Do as described earlier if you can wind all the way up and support the lid with lengths of timber. Because if the rear cables snap alltogether it is a very difficult job to lift the lid. Four guys will be needed.
I took my cables to a ships chandlery to have them make new at a fraction of the cost from jayco. Replace the corner pullies with the newer metal ones. You will find the cable length is adjusted at the whiffle tree near the winch so each corner comes up to the same height.
My cables broke while camped at the Mitchell Plateau and we had to tent it for the next three weeks home.
Hope this helps
Stan
AnswerID: 408908
Reply By: phil300 - Monday, Mar 15, 2010 at 15:06
Had one about that year many moons ago.
Can you push the top down or dose it lock solid.
AnswerID: 408924
Follow Up By: maggie63 - Monday, Mar 15, 2010 at 16:48
i have been messing with it most of the morning have managed to get it right down except for one corner which is sitting about 30mm higher all the other corners went down flat
FollowupID: 678917
Reply By: woodie3 - Monday, Mar 15, 2010 at 15:50
Hi, I have a Coromal camper and would think Jayco mechanism is similar, I have photos of mine , If you email me at billkelly@iprimus.com.au I will send them to you, cheers Bill
AnswerID: 408932
Follow Up By: maggie63 - Monday, Mar 15, 2010 at 16:49
thanks my email is kms978@bigpond.com
FollowupID: 678918
Reply By: Hooroo WA - Monday, Mar 15, 2010 at 18:08
Hey Maggie,
If I am right in what you are saying, our Jayco Swan used to stop before touching the bottom but it was designed to do that.
The last bit closes with the latches so you can check all your canvas is tucked in etc
Cheers, hope this helps
AnswerID: 408960
