gearbox rattle in reverse.
Submitted: Wednesday, Mar 17, 2010 at 22:12
ThreadID: 76961 Views:2466 Replies:2 FollowUps:1
Hi, im a new member to the forum. I have a '93 2.8 diesel 4runner, 5 speed and lately when reversing up my steep gravel driveway ive been hearing a rattle noise. At first i thought it was stones being kicked up and hitting the side steps but then today at the beach it did the same thing! Any ideas as to what is causing this? i havent noticed any other issues with the gearbox, in first gear up the driveway its fine!!
Reply By: Rangiephil - Thursday, Mar 18, 2010 at 09:54
wear?
Regards Philip A
AnswerID: 409326
Reply By: loxsmith - Thursday, Mar 18, 2010 at 13:11
Check if the pinion nut on the front of the rear diff is tight and the lock tab is still bent over. That's my most likely guess of the noise! You will have to unbolt the tail shaft first!
Glen
AnswerID: 409345
Follow Up By: 4running - Thursday, Mar 18, 2010 at 18:37
thanks loxsmith!, have never removed one before but will give it a go! reverse gear makes no other noise other than when wheels are slipping so maybe it could be a simple thing and im just thinking the worst eg gearbox failure!
FollowupID: 679332
