Is it possible to turn on a net book pc from a reote touch screen?
Submitted: Saturday, Mar 20, 2010 at 21:50
ThreadID: 77045 Views:3360 Replies:3 FollowUps:11
Hi all
One for the IT crew.
Can you somehow turn on a net book pc from the remote touch screen somwhow???
GN
Reply By: Member - Christopher P (NSW) - Saturday, Mar 20, 2010 at 21:59
if you go into the bios you should be able to see "wake-up from usb"
more spec's about the netbook would help????
if you put the details up we can help you better????
AnswerID: 409681
Follow Up By: Member - G N (VIC) - Saturday, Mar 20, 2010 at 22:27
Hi Christopher
sorry for lack of detail
The net book is a Toshiba NB100.
GN
FollowupID: 679618
Follow Up By: Member - Christopher P (NSW) - Saturday, Mar 20, 2010 at 22:37
give me a couple of hours to do a search for required inof.
FollowupID: 679622
Follow Up By: Member - Christopher P (NSW) - Saturday, Mar 20, 2010 at 22:43
press F2 for the setup utility at startup
to get into bios and search thru the bios till you find a sleep mode or wake from sleep
select wake from usb
that should then give you the option to wake your netbook from your touch screen.
it acts like a mouse type
if you stuff it up, look for reset to default on main bios page.
look thru bios first though to get a feel for everything. that way you will get confident using the bios and make less mistakes.
don't worry i have made so many mistakes that is easy to fix.
FollowupID: 679623
sleep mode should be in power settings
FollowupID: 679624
Follow Up By: Member - G N (VIC) - Saturday, Mar 20, 2010 at 22:48
Christopher
Will give it a try tomorrow and let you know how it goes.
Many thanks for your help.
GN
FollowupID: 679626
Follow Up By: Member - Christopher P (NSW) - Sunday, Mar 21, 2010 at 07:45
No probs
FollowupID: 679638
Follow Up By: Member - G N (VIC) - Sunday, Mar 21, 2010 at 16:09
Hi Christopher
i gave it a go and found the control panel via F2 but does not have a ""wake from USB"option.
i must of done something while fiddling iether there or else where as the touch screen now not displaying or in sync.
will have to get IT man to reset.
my IT skills are zip i am afraid.
IT man did have a go at starting from touch screen but wasnt able, but i have found info on net and here before that has enabled us to do stuff that IT man didnt know of.
regards
GN
FollowupID: 679684
Follow Up By: Member - Christopher P (NSW) - Sunday, Mar 21, 2010 at 17:37
At least you tried
do you have a msn account
if you do i can do something from this end
my msn is chris_pollock5@hotmail.com
if you don't it's free to setup and easy to use.
if you go into to bios you can reset to default should be on your main bios page.
FollowupID: 679709
Reply By: Member - Aaron L (NSW) - Sunday, Mar 21, 2010 at 06:51
Hi GN
Im currently looking at creating a similar setup, could you let me know which touch screen you have and thoughts on it. cheers Aaron
AnswerID: 409705
Follow Up By: Member - G N (VIC) - Sunday, Mar 21, 2010 at 16:06
Hi Aaron
the touch screen is a Xenarc #705TSV
havnt used it enough yet to be sure its good, IT bloke got one in and said it was crap to see and sent it back and got this for me.
Regards'GN
FollowupID: 679683
Reply By: mikehzz - Sunday, Mar 21, 2010 at 08:03
All the above will only work if the connection is USB. If the screen is attached using the av out video cables then there is no way for you to do it.
AnswerID: 409706
Follow Up By: Member - G N (VIC) - Sunday, Mar 21, 2010 at 16:04
Hi Mike
the touch screen is connected via a rear serial port as well as a USB connection
GN
FollowupID: 679682
Follow Up By: Rossc0 - Wednesday, Mar 24, 2010 at 13:20
I'd suggest that this is actually the rear video port (15 pin connector) rather than a serial connection and a USB connection.
The touch screen would not be working at all if only attached via the AV out video cables as all touch screens basically act in place of the mouse.
It may be that rather than "wake from usb" you need to use "wake from mouse" and set "usb mouse" active in the bios.
Ross
FollowupID: 680077
