Memory Map & Hema Navigator
Submitted: Monday, Mar 22, 2010 at 14:49
Member - Pam P (VIC)
Hi, If anyone has successfully loaded Memory Map (particularly Vic_Topo T3 maps) to their Hema Navigator, I would love to discuss how you managed it! Regards,Pam (palmergp@bigpond.com)
Reply By: Sand Man (SA) - Monday, Mar 22, 2010 at 20:01
Pam,
I assume you mean loading additional maps???
Hema Navigator has Memory Map (the application) pre-loaded.
Providing the maps are compatible, you simply load them to the SD card and Memory Map should pick them up.
After starting the Memory Map application, tap one of the options (eg Topo) then select Planning Mode - Navigation Mode - then click the hammer/spanner symbol (second one along the top) and a menu should appear showing Map at the top.
When you select this Map icon, a list of maps will appear and assuming you have loaded your additional maps to the same directory on the SD card and it is compatible with Memory Map, it should be displayed in the available map list.
Bill.
409948
