Friday, Mar 26, 2010 at 09:47
Jeremy,
The way a Solar panel works is charge a battery that is close to full, because you drove to where you will be
camping anyway, the battery will be fully charged when you arrive at the
camp site.
Then the solar takes over when you stop, the panel puts out about 5 Amps (80 watt) if required by the battery, at the same time the fridge is using about 6 Amps, running on a 50% duty cycle so when it stops the panel makes up the 1 Amp lost from the battery till the fridge restarts again.
So at the end of the day the battery is close to fully charged and able to run the fridge and lights etc all night, then it starts again to recharge the battery again next morning.
If it's in a cool climate the fridge won’t be using so much power anyway and the solar system won't have any hassles if it has been correctly specified for the accessories you have.
This photo shows a Steca regulator LCD screen with a charge/discharge Ammeter and battery voltage gauge underneath, showing the fridge is drawing ~8 Amps and battery is still 13.1 Volts
When the fridge stops, as it does every 20 mins, the entire 4.9 Amps will again charge the 13.1v battery system back up to the 13.8v trickle charge rate.
Image Could Not Be FoundMaîneÿ . . .
680357
