Landcruiser turbo diesel lack of power
Submitted: Tuesday, Mar 30, 2010 at 20:39
smada choice
I have a 2006 Landcruiser Turbo Diesel that has a lack of power. Drives like there is no turbo at all.Had the turbo checked ( all OK ) engine checked ( all OK ) Has anyone had this problem at all or any suggestions on what the problem could be
Reply By: Territory29 - Tuesday, Mar 30, 2010 at 20:48
I once had a blocked muffler sounded good and went
well at low revs but under load or at speed just did not go, might be worth checking. Will be interested to hear what the outcome is.
greg
411107
Follow Up By: smada choice - Friday, Apr 02, 2010 at 18:33
I had the muffler clecked All Ok thanks for the thought
681511
Reply By: Member - Phil G (SA) - Tuesday, Mar 30, 2010 at 21:00
Yep.
My 1HD-FTE had gradually been getting gutless. Then it started making a funny noise when you put the foot down at 3000rpm. The exhaust to dump pipe flange is sprung and was popping open from backpressure - could see black marks from this.
What has happened is the cat converter can block up with carbon. Three weeks ago, I replaced the whole system with a 3" exhaust and it has made a huge difference.
411108
Follow Up By: smada choice - Friday, Apr 02, 2010 at 18:35
I had the exhaust checked along with the muffler as previous suggestion ALl OK thanks
681512
Reply By: Member - Graham H (QLD) - Tuesday, Mar 30, 2010 at 21:47
Mine did that after a service that included tappets.
they had left off one of the little rubber tubes that run across the rocker cover.
Felt like a 1 HZ Hooked it up and no more troubles
Worth checking as only by pulling gently at each one did I find it.
411116
Reply By: Dan - Yal - Tuesday, Mar 30, 2010 at 21:48
I had an 80series TD that I took in for an RAC check for a prospective buyer. The guru's that inspected the vehicle disconnected one of the turbo hoses and didnt reconnect it. After this, the turbo didnt kick in and the drive was gutless. Just like yours, it was driving like there was no turbo.
Once I found the loose hose under the bonnet, I reconnected it and the cruiser drove like a dream.
Maybe have a squiz around for any loose hoses.
Good luck
Dan
411117
Reply By: Member - Graham H (QLD) - Saturday, Apr 03, 2010 at 12:16
Would be nice if on these type of threads the original poster would come on and
say how they fixed it, if in fact they did.
Rather than leave us all holding our breath waiting waiting waiting..............
411518
Follow Up By: smada choice - Saturday, Apr 03, 2010 at 15:32
Still having the problem looked at will let you know when I find what the problem is Thanks
681594
Reply By: Alec L - Saturday, Apr 03, 2010 at 17:34
i had the same problem with a hzj79. non turbo. it was more gutless than a hj45. the problem was that the previous owners used poor quality
fuel filters and buggered the injector pump. reconditioned the pump and injectors and goes much better now. its very costly though. it was so gutless it couldnt run the air conditioner at idle, it clonked out.
i recommend taking it to a diesel specialistl like denco diesel.
411542
