Help Plan our Trip
Submitted: Wednesday, Mar 31, 2010 at 07:53
ThreadID: 77336 Views:4091 Replies:6 FollowUps:1
We are currently located in Byron Bay hoping to head to Alice Springs end of April. We were thinking heading up to rockhampton and then LOngreach to Winton. From there we are planning to take the kennedy develomental road, donahue hwy and plenty hwy. We are driving a 2002 Prado on Duel Fuel. Towing our Sunwagon I can get roughly 350-370kms on LPG and I am assuming the SubTank of petrol will roughly do the same giving us a around 700 km range. Is there suffcient petrol stops as I have noticed the last LPG along this route is Winton.... I was going to carry some fuel (50Ltrs) as well. Does anyone suggest maybe starting to go inland before Rockhampton? Thanks
Reply By: Member - Teege (NSW) - Wednesday, Mar 31, 2010 at 08:32
DrOcelot
I am assuming that your 2002 Prado is a 90 series(original shape), rather than a 120 series. That being the case I think you are a little ambitious with your expectation of 350-370 km from the sub tank. When towing my 1100kg caravan on the bitumen I am happy to achieve 350. However, your fuel consumption can be expected to rise markedly once you get on a road like the Plenty Highway. You will have to lower your tyre pressures, which, giving you a larger footprint will increase consumption, and dragging the camper through corrugations and bulldust will make that even worse. You can assume this will have the same effect on your consumption of gas (if you have any by then). Have you had a look at the trek note for the Plenty Highway Have a look heretrek note
AnswerID: 411153
Reply By: brushmarx - Wednesday, Mar 31, 2010 at 10:03
We did Winton through to Alice at Christmas, and conditions obviously change, but we did not notice any significant increase in fuel usage through corrugations and bulldust, compared to travelling on bitumen. I reduced tyre pressure by 5, but the slower dirt road travel more than balanced out the potential higher fuel use from higher bitumen speeds.
I guess it relates to vehicle speed as much as road conditions, and both vary greatly with changing situations.
Our trip was in a petrol Monterey with 1250kg of CT, and just after heavy rain, with no road grading done.
There's a bit of a shortage of service stations out there, but I would suggest you call ahead to make sure they have fuel where you expect it, rather than drive up and find out the fuel supply ran out.
Just standard planning required.
AnswerID: 411157
Follow Up By: Member - Oldplodder (QLD) - Thursday, Apr 01, 2010 at 09:08
Same here with the C/T.
Looping along at about 80km/hr on good tracks we get better consumption than at 100 on the highway. Even with lower tyre pressures.
Found the same when we crossed Plenty many years ago. Most of it was good 2 lane dirt road.
Didn't need to refuel between Boulia and Alice, but then we had 135l main and 70l sub tank. :o)
Sub tank is gone, but we carry a couple of jerries on the CT for 1300km range.
Jervois station still doing fuel? Friend filled up there who only had a 90l standard tank.
FollowupID: 681354
Reply By: Member - John and Val - Wednesday, Mar 31, 2010 at 11:05
Can someone confirm whether Jervois still only takes cash? That was the case when we were last there in 07
Val.
J and V
- Albert Einstein
AnswerID: 411165
Reply By: Member - Oldbaz. NSW. - Wednesday, Mar 31, 2010 at 14:02
According to the Road Conditions reports elsewhere on this site The Donahue
& Plenty highways are both closed due to flooding, so may be wise to check
as you get closer to those areas....oldbaz.
AnswerID: 411190
Reply By: DrOcelot - Wednesday, Mar 31, 2010 at 14:59
can anyone recommend a better way to getting to alice springs from Byron Bay or East Coast? I am concerned by the lack of range and would like to stay on bituman as much as possible. Also I have no real time liimits
AnswerID: 411194
Reply By: Motherhen - Wednesday, Mar 31, 2010 at 15:06
Hi DrOcelot
I would also question how your Sunwagon will survive a long corrugated road such as the Plenty.
It is a pretty good bitumen road Winton to Boulia (with lots to see in both towns) and on to Mt Isa. Then the Barkly Hwy and on to the Stuart Higway.
AnswerID: 411195
