UHF Repeaters
Submitted: Saturday, Oct 11, 2003 at 14:14
CJ
When using a repeater, you must transmitt on (1-8) and receive on (31-38). How are you meant to have a two way conversation if you and the other person are not constantly changing between 1-8 and 31-38. If you have one radio on 5 Duplex and another on 5 Duplex, can they communicate? How far do the radios have to be seperated before they can use the repeater without giving each other interference?
Please Help!
Reply By: chopper - Saturday, Oct 11, 2003 at 14:18
if you have selected duplex on a particular channel (say 8) your radio will automaticly transmit on ch 38 and then recieve on 8. If you are within the range of a ch 8 repeater it will pick up your transmission on 38 and simultaneously transmit (repeat) it on 8.
You do not have to switch between channels manually.
Stay off ch 5 (and 35) it is designated for emergencies only...
chopper
33427
Follow Up By: CJ - Saturday, Oct 11, 2003 at 14:23
Thanks for that, I haven't yet tried the duplex on long range, so ill try it soon.
23998
