Trouble with - Downloading Treks
Submitted: Friday, Apr 02, 2010 at 18:47
ThreadID: 77407 Views:2993 Replies:2 FollowUps:4
After selecting
Download Trek and then selecting Gpx as format
the file appears in my downloads.
I can't work out what happens from here. Any help would be appreciated.
Rob
The outback calls
Reply By: Member - John Baas (WA) - Friday, Apr 02, 2010 at 19:01
Hi Rob,
just copy it and paste into a folder that you can then access it from via Ozi or whatever program you'r' using. Rename it to something useful.
Cheers.
AnswerID: 411444
Follow Up By: Navigator 1 (NSW) - Friday, Apr 02, 2010 at 19:12
Hi John,
Did CTRL C and then CTRL V to paste it into the folder where I store ExplorOz downloads but nothing happens.
Rob
The outback calls
FollowupID: 681518
Reply By: Member - Terry (SA) - Friday, Apr 02, 2010 at 19:41
Hi Rob
You can not copy and paste a Gpx. file. From OziExplorer go to Load>Import GPX file then navigate to your downloaded file. This will open the relative file.
If using OziExplorer it is better to download the Trek in OziExplorer format. See details here Trek download
Trust this helps
Terry
AnswerID: 411450
Follow Up By: Navigator 1 (NSW) - Friday, Apr 02, 2010 at 19:52
Thanks Terry,
All done! Its amazing how you forget things when not done often.
Robyn
The outback calls
FollowupID: 681523
Follow Up By: Member - John Baas (WA) - Friday, Apr 02, 2010 at 20:56
Hi Terry and Rob.
You can copy and paste a GPX file. I did forget that you need to right clk the file to open the 'containing folder'. You then need to copy/paste to the desired folder.
It then stores as a GPX file which you need to import into Ozi using the 'import GPX' option under the Load button.
I've just done it and it has worked perfectly incl the waypts.
But I agree that downloading it as Ozi format in the first place is also good.
Cheers.
FollowupID: 681531
Follow Up By: Navigator 1 (NSW) - Monday, Apr 05, 2010 at 13:33
Thanks John, This is the way I remember doing it. But, as you say, it is good to do both.
Rob
The outback calls
FollowupID: 681724
