Jayco Wardrobe Query?
Submitted: Friday, Apr 02, 2010 at 21:52
ThreadID: 77413 Views:5004 Replies:5 FollowUps:2
Hi All,
I am still setting up my Jayco Penguin and am seeking any info on the useless wardrobe that folds down. Has anyone done something special that makes it more usefull? We have played with storage containers to hold undies etc but whatever we do it needs to be secure when it tips over.
I am sure that someone out there will have some bright ideas.
Thanks,
Steve
Reply By: Member - Teege (NSW) - Friday, Apr 02, 2010 at 21:58
Steve
Yep, they're even too flimsy to use as a table while folded down. When we had one we used it as a linen press and just stuck our hand inside the door when we opened it to stop everything falling out. That worked until the hinges pulled out. Then we threw it away.
teege
AnswerID: 411467
Reply By: HGMonaro - Friday, Apr 02, 2010 at 22:10
our wind-up (not a Penguin) normally would have one but we got them to remove it and make the bench longer.
AnswerID: 411470
Reply By: Member - John & Sally W (NSW) - Saturday, Apr 03, 2010 at 00:23
Hi Phantom,
Yep, completely useless. We removed it and put a square of 7 ply attached to the hinge. Covered a square block of foam, two strips of velcro on foam and glued 2 strips of velcro on ply. Extra seat and not so squeezy beside the stove when cooking. Made getting to the other storage areas easier too.
Sally
AnswerID: 411490
Follow Up By: Member - John & Sally W (NSW) - Saturday, Apr 03, 2010 at 09:00
Hi Again,
We also removed the cupboard that is suspended above the bed. Anything heavier than a roll of toilet paper makes it reluctant to stay attached to the ceiling on rough roads. We just plugged and painted the holes.
Sally
FollowupID: 681572
Follow Up By: PradOz - Saturday, Apr 03, 2010 at 14:49
I always thought jayco did a poor job installing those overhead cupboards. Wish you had of thrown yours my way ;) - would have loved to try fit one in my Swan ....
FollowupID: 681593
Reply By: PradOz - Saturday, Apr 03, 2010 at 14:46
Hi Steve
I fitted removable shelves in mine. 5 from memory. I fitted a timber support on each side and back glued in place. Across the front i used 20mm x 20mm aluminium angle. I cut out from 1 face at each end enough to allow it to sit on the side supports. That way i can move the angle to gain access to a shelf, or completely remove a shelf if i want to. Also makes it easier to put each ply shelf in there. I havent nailed ply down. When you fold cupboard down it tends to keep the angle in place. I rarely have it moved enough to dismantle the contents. If you travel really rough tracks you may want to screw it down to secure and it could be removable by removing screw if you want to. At the bottom i just sat a piece of ply to cover the deep base section. I ended up with a concealed box at the bottom of the robe so when you put some clothes etc on top it covers up that you have a hidden storage area there. Handy to 'secure' things away from view. I have a full oven in my Swan and have always thought about lifting my robe to place a microwave space below it. Would mean i either have to come up with a drop down hinge to lower the robe onto its normal position when its folded up or manually lifting it up/down. One day.... My brother uses his robe as a pantry with shelves in his. My other brother got rid of his and has a full length bench top. Have fun....
AnswerID: 411527
Reply By: Member - Terry W (ACT) - Tuesday, Apr 06, 2010 at 09:31
I removed mine, disassembled it, and cut it down so that with the top back on it was exactly the same height as the bench. Then I screwed it down (without the hinges).
We used it for storing the kettle and coffee things, and used the top for making coffee etc.
Cut down, it was very useful indeed.
AnswerID: 411786
