80 series gearbox
Submitted: Saturday, Apr 03, 2010 at 22:40
Adamjapan
Hi all, Its been a while, I have a problem with my gearbox, when I am travelling at just above 60kmh I will be in top gear, when I take the gas off to corner or to stop the gearbox will change down the gears, before it would also do that but I would not feel it, it feels like I'm driving a manual because the gear changes are so prominent.
I changed the oil, that's all.
At the moment I am running stud-less tires because I'm in Japan and we still getting some snow and ice on the road.
Any advice would be great.
Oh and I did go to the Toyota
shop and they just want to rip the gearbox out and have a look and charge me $2500.
On another side note, I had my starter motor changed for free as it was a recall item, don't know it this is a world wide thing, just thought I would let you know.
Reply By: Member - Stuart P (WA) - Saturday, Apr 03, 2010 at 22:49
sounds like a vaccuum problem
411563
Follow Up By: Adamjapan - Sunday, Apr 04, 2010 at 11:00
Hi thanks for the reply, how do I fix this vacuum problem?
681630
Reply By: PeterInSa - Sunday, Apr 04, 2010 at 11:52
ADAM,
If you have an LC other than the current model , suggest you become a memeber of www.outerlimits4x4.com, they provide great help and advice.
411603
Reply By: Member - Graham H (QLD) - Sunday, Apr 04, 2010 at 12:20
I had a similar problem recently and the cause was that they had pinched and cut an O ring somewhere near the filter in the Auto. Was allowing it to suck air and made kickdowns really thumpy
This was after an oil change as
well but
mine is a 100 ser with the 5 speed
411607
Follow Up By: Member - DOZER- Sunday, Apr 04, 2010 at 19:15
there are 3 autos in the 80 series range, which one do u have? I would suggest you check the kickdown cable is not stuck in the full open position, which gives the auto full pressure.....if it looks ok, give Rodney at Whlesale automatics Bayswater
Melbourne a call, he is the pro and will have an answer or direction.
Andrew
681671
Follow Up By: Member - DOZER- Sunday, Apr 04, 2010 at 19:17
If you have the overdrive button on the shifter, is the od light on the dash flashing when you select overdrive?? (This indicates a fault code is stored) could be accelerater tps switch, speed sensor aswell, guessing your speedo is working from the mention of speed.
681672
Follow Up By: Adamjapan - Sunday, Apr 04, 2010 at 23:37
Hi Dozer,
Thanks for the help and advise, I ended up in the Toyota
shop and they stuck it on the diagnostics machine and a code 64 came up, in this gear box there are 4 solenoids and one of then has had it, they advised me to change all of them, the end price for repair will be $650.00.
I'm booked in for next week, you would think they could do it on
the spot considering I'm in Japan.
Again thanks.
Adam
681684
Follow Up By: Member - DOZER- Monday, Apr 05, 2010 at 08:00
Adam
Good news re finding the issue. It is not uncommon for a solenoid to go. I would ring an auto service centre and get a second quote, because the solenoids are very easily changed once the pan is off... (which they remove to change the filter for a standard service)
Andrew
681699
