water degradation
Submitted: Sunday, Apr 04, 2010 at 15:45
Member - Thomas A (QLD)
hi everyone does any one know if
water degenerates if left in a caravan underfloor black plastic
tank and only occasionally topped up? it appears and tastes just fine. also what is the capacity of the average caravan
tank? many thanks in anticipation thomas qld
Reply By: Motherhen - Sunday, Apr 04, 2010 at 16:08
Hi Thomas A
So long as it is in the dark so not algae can build up (and it is) it lasts for ever. We don't drain our tanks, even if the van has been left sitting for two years. Likewise our home
water tanks which just get topped up with the rain. For those using
water from underground sources (which is part of many city supplies) that has been sitting underground for tens of thousands of years. All good
water.
Capacity? Depends what
tank you have fitted. Ours have 80 litre; some tanks are 60, some 100, and probably many other sizes. I think our first caravan had around 20 litre
tank.
411629
Reply By: Member - Allan B (QLD) - Sunday, Apr 04, 2010 at 16:15
I agree that in a black poly
tank the
water will stay potable for a very long time but it may absorb some taint from the plastic. So to be sure, I drain and refill ours prior to each trip.
411630
Follow Up By: snailbait (Blue mntns) - Sunday, Apr 04, 2010 at 18:22
I would always fill up with town
water which has clourine int . this should keep it potable do not fill up with river
water or rain
water if you do drain it when your get home and refill with town
water
terry
681665
Reply By: Member - Andrew (QLD) - Sunday, Apr 04, 2010 at 19:19
No worse than every rainwater
tank on a house, possibly better as the residual chlorine introduced when filling from the tap may provide some help for a short period of time.
Andrew
411652
