ARB Awning
Submitted: Tuesday, Apr 06, 2010 at 00:18
Member - Howard P (WA)
Hi All
Has anyone out there fitted an ARB awning to a Tracklander roof rack (100 series cruiser) if so, and I'm sure there is - what's the easiest way/or method used to install it so that it does not intefere with the perspex wind guard that protrudes about 25mm past the side bars of the roof rack.
Thanks in advance for your help.
Reply By: Dasher Des - Tuesday, Apr 06, 2010 at 09:56
I guess that you have two options.. 1. Fit a 30mm spacer and buy some longer bolts or 2. Cut the perspex back by 25mm.
411790
Reply By: Member - evren1 (WA) - Tuesday, Apr 06, 2010 at 11:32
Howard,
don't cut the perspex .....
the mounting bracket and spacer is a tracklander accessory. the pictures below will show you.
hope this helps.
Evan
Image Could Not Be FoundImage Could Not Be Found
411797
Follow Up By: Member - Howard P (WA) - Tuesday, Apr 06, 2010 at 19:12
Thanks Evan,
Very much appreciated, I will get some at Tracklander next time I go down the
hill. Certainly saves a lot of mucking around trying to make something up.
681883
