portable welding
Submitted: Thursday, Apr 08, 2010 at 09:42
Member - Rona G (QLD)
Can anybody tell me the best set up for taking a portable welding equipment when travelling the outback. rgds
Reply By: Member - bungarra (WA) - Thursday, Apr 08, 2010 at 10:08
There have been numerous posts on this subject over the years and so without repeating it all I suggest you do a search on this site and you will find all you need in some good posts and
blogs
Using two batteries is the cheapest option and works a treat if you have some welding experience........the more expensive option is a portable MIG but very versatile
I have used both over the years in break down situations
412087
Reply By: Shaker - Thursday, Apr 08, 2010 at 10:09
There are several alternator/welders that are available to replace the standard alternator on your vehicle.
412088
Follow Up By: Shaker - Thursday, Apr 08, 2010 at 10:14
Have a look here at
UNIPOWER
682066
Reply By: B1B2 - Thursday, Apr 08, 2010 at 10:23
G'day Rona,
The method I find best for me is using 3 batteries, spare jumper leads with terminals, a welding mask lens and 2.5mm rods. 36vdc is a bit too much unless welding vertical up, so I use a piece of flat bar, say 10mm x 1mm in series bolted to one of the jumper leads clamps, and can regulate the voltage. Some have used loops of fencing wire for this, but it glows red hot and can sag and touch the ground.
As an electrode holder I have drilled a set screw to fit the welding rod and tighten the rod up with
the nut. This set screw with rod can now be held firmly in the jumper lead clamp without moving when striking an arc.
I have used this set up for a few repairs in the bush, and the welding mask can be made up of carboard from a slab and tape the lens in.
Hope this helps.
Bill
412093
Reply By: Hairy (NT) - Thursday, Apr 08, 2010 at 13:23
Gday,
The power source is up to you, but I would just use batteries.
Dont forget a helmet, gloves and a few different rods.
WIA 12p are a good out of position GP
Weldal's are expensive but a very good dissimilar metals rod.
WIA 16TCLow Hydrogen for the heavier duty stuff.
WIA Supercast Ni for any soft cast jobs.
412119
Reply By: Member - Beatit (QLD) - Thursday, Apr 08, 2010 at 14:42
G'day Gitsho,
I like the inverter welder and generator approach. Have a look at thread 75552 about half way down to view the set up.
Kind regards
412125
Reply By: brushmarx - Friday, Apr 09, 2010 at 09:19
This may be considered a bit of a hijack, but it is related.
But if is a hijack , I apologise.
My query is regarding welding rods.
In the recommended 2.5 diameter rods, are there better quality rods, or easier to use rods for amateurs?
I have a small stick arc welder, but spend more time with the rod stuck to the steel, tripping the power circuit.
Using car batteries, there wouldn't be a circuit breaker, so I was hoping there is some safety in improved rod quality.
Does anyone with welding experience know this?
Are
SuperCheap rods (and the like) the same as trade quality?
Are there different colour codes or brands or something else to help differentiate?
Ian
412235
Follow Up By: Tonyfish#58 - Friday, Apr 09, 2010 at 18:03
Ian - If you are having trouble starting your rod it may be technique or you may just have to wind the amps up a bit.
I have found as an amateur who likes and does a fair bit of welding that most rods will fire up ok as long as you have the right amps. At other times you have go a bit lighter on the touch at start-up. Sometime
the tip gets coated and you have to fire it up off the work to clear the rod tip.
NEVER TRIED WELDING WITH BATTERIES TO DATE - But I am sure you would just need good technique. Cheers Tony
682256
Reply By: Member - mazcan - Friday, Apr 09, 2010 at 14:34
hi rona g
have a look at the site for ready welder
www.readywelder.com.au
might suit your needs or maybe not
412264
Reply By: Mick O - Friday, Apr 09, 2010 at 19:33
Hey Gitsho,
I have made up a portable stick rig that I carry with me. It's a bit hit and miss and works best with three batteries (36V). I have done a blog on our major episode out on the Sandy Blight 2 years back. Here is the link;
A day of bush welding
There have been a couple of good threads around trhe subject on the site of which this is one.
Bush Welding - Thread 60700
I have secured one of the Ready-welders mentioned above from the USA where it is less than half the cost that it is here. While I hope I don't have need of it this trip, I will be using it to gain some level of proficiency so will no doubt give a report later on.
Hope this helps.
Mick
412285
