Cleaning Watern Tank on Camper Trailer
Submitted: Thursday, Apr 08, 2010 at 16:27
Member - Wayne B (NSW)
I need to remove my
water storage
tank and clean it out. What is the best chemical to use to remove any unwanted bugs etc. I gather you don't use this
water for drinking anyway but I would like to be sure it is as fresh and clean as possible
Wayne B
Reply By: Notso - Thursday, Apr 08, 2010 at 16:42
I don't know about anyone else but I certainly use my
water tank for
drinking water.
The best thing for removing odours etc is ordinary old BiCarb soda.
Half fill the
tank, mix up about 500 grams of BiCarb in a bucket of warm
water then pour it into the
tank. Then fill the
tank to the top and leave it soak overnight.
Then flush it a couple of times with
water. Now if you are on a town supply the
water should have one or two ppm of residual chlorine in it out of the tap so that will also help to keep the
tank hygienic once you have cleaned it out.
If the
tank is grossly contaminated then ordinary household bleach at around 250millilitres to a full
tank of
water left overnight should clean it out OK. Do this after giving it a good flush out with
water.
Algae needs light to grow, but some bacteria will grow in the
tank given a chance.
412138
Reply By: Hairy (NT) - Thursday, Apr 08, 2010 at 16:51
Gday,
I put half a cup of chlorine in
mine and bounced it around a dirt track for half an hour....then flushed it and did the bi-carb soda trick as above and bounced that around the track.......a good flush and never had a problem with it.
412141
Reply By: uneekwahn - Thursday, Apr 08, 2010 at 17:45
Milton's sterilising tablets as used for baby's milk bottles.
412146
Follow Up By: Member - Wayne B (NSW) - Thursday, Apr 08, 2010 at 17:57
Thanks Guys. I wanted to clean the
tank because I just purchased the camper trailer and I dont know how long the
water has been left sitting in the
tank.
I have removed the
tank and the
water that was in there looked ok. However I have added Bi Carb and will leave it over night then flush out in the morning.
Thanks again
Wayne B
682116
Reply By: john&thejayco - Thursday, Apr 08, 2010 at 19:49
G'day Wayne,
what ever you do don't use that clr clean, I went fishing with some mates, out on the Barwon a couple of years back and someone had cleaned a plastic
water container out with , and you couldn't drink the
water out of it ,it even had a real strong smell. It might be fine in glass or other materials but not plastic.Luckily we had other
water and the river
water was ok anyway, plus we had some little brown bottles in the esky just in case.My father bought a fold up caravan that had the strong smell of stagnant
water and he used a product from a
camping store just called
tank cleaner,and it took the smell away completely. Hope this helps.
Cheers.
John.
412164
Reply By: landed eagle - Thursday, Apr 08, 2010 at 20:45
I had a 'smoky' taste in the
water in my tanks a while ago.Flushing tanks didn't make it go away.
Filled them with a powdered cleaner for home brewing bottles ( half a bottle of diluted powder in each
tank).
Topped tanks right up and let sit for a couple of days. Drained,re-filled to flush,drained again then filled.
Water tastes like
water now some 6 months later.
412173
Follow Up By: Member - Wayne B (NSW) - Thursday, Apr 08, 2010 at 21:01
Come on tell the truth you were just trying to smuggle liquor into the No Liquor Areas. LOL
682140
Reply By: Spade Newsom - Friday, Apr 16, 2010 at 00:49
Not sure if it needs saying but make sure you use food grade hose to fill the
tank. Garden hoses give the
water a horrible taste.
I also use
mine for
drinking water.
413092
