I ended up making my own roof bars for my Roof Top Tent
Submitted: Saturday, Apr 10, 2010 at 23:03
ThreadID: 77622 Views:4897 Replies:2 FollowUps:4
I posted about roof bars a few weeks ago, I didn't want to buy Rhino Bars as I didn't think they are worth the money, although I believe they are of good quality. The other option was buying a full length rack, about 60 kg and then it sticks up about 220mm higher than the Patrol, so its heavy, high and ugly and I'm stuck with lugging it around everywhere. The bars I made are only 60mm higher than the Patrol and once the awning is removed together with the end brackets, and weigh 5kg each, so a big saving on weight when using the vehicle , day to day, and looks a bit better.
Making my own didn't end up being a whole lot cheaper, if at all, They are made from 50 x 25 x 3mm RHS, 6mm end plates and powder coated. I incorporated brackets on the end on the passenger side for my awning and set it a little higher so I can stand under it without crouching down and also added a shovel holder.
I made three bars, the front primarily to support the awning and the other two for the tent. The awning is removed easily by taking out the 3 bolts on the end of the bars and can be handled by one person. I have to make an adjustable air deflector to mount to the front bar to get the air over the tent, I have a piece of 6mm Polycarbonate for that purpose.
The 6 ends of the bars have a block of steel welded in them and tapped M10 so I can make side bars if needed later on and i will make a bracket for the front drivers side bar for my sand flag.. I gives me a little flexibility..
I used the S/S brackets from my Formula Offroad Alloy roof rack but I designed 2 brackets in to each end of each bar so i could get the cross bars lower to the roof (60mm), so i had to buy another 6 brackets. The steel $70, powdercoating $130, extra 6 brackets $150 plus a set of Kwik Fists for the Shovel holder $18 delivered. Still OK price wise I think and they are really strong and suit exactly what i want. MichaelImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
Reply By: Member - Andrew L (QLD) - Sunday, Apr 11, 2010 at 06:30
They look great, and functional, well done mate.
The satisfaction of doing them yourself would far outway opening a new box of some manufactured ones.
AnswerID: 412459
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Apr 11, 2010 at 10:51
Thanks Andrew,, Michael
FollowupID: 682527
Reply By: Member - Nick (TAS) - Sunday, Apr 11, 2010 at 08:57
Just done pretty much the same thing but instead of bars, I built a full rack with only 1/4 cage on top bar.All up weight is 29kgs, cost about $100 in steel but the gutter brackets took nearly a day to build by them selves but happy with end result.
AnswerID: 412471
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Apr 11, 2010 at 10:50
Nice job Nick, I wanted the low height so went for the bars and also its hard to wash the roof with a rack on, you can never find anyone about to help remove the damn thing when you want.. It would have been nice to have the front area useable like yours, but i generally take my trailer so i have plenty of space anyway.. How do you fing the standard mattress in the roof top?? i'm yet to try mine out... Michael
FollowupID: 682524
Follow Up By: Member - Nick (TAS) - Sunday, Apr 11, 2010 at 11:25
I actually went a little higher than a normal rack so the tail gate would lift up higher.
We wanted the option of leaving the trailer behind and only taking the roof topper so thats why I went for the bigger rack.I slide it forward when we have the trailer on(level to the top bar ends) and move it back when no trailer so our rack bag fits in front.
Havent used the roof top tent yet but want to try to it out once before winter sets in here.Feels ok to lay on for short periods.........
And I agree, its abit of a pain getting the rack on and off without scratching the roof, especially when your vehicle is 4" higher than normal.Im going to take it off for winter and then leave it on for summer.
FollowupID: 682534
Follow Up By: Member - Nick (TAS) - Sunday, Apr 11, 2010 at 11:27
BTW, nice job too.
FollowupID: 682536
