F250 filters and belts
Submitted: Sunday, Apr 11, 2010 at 19:21
Member - Carl
Not long ago I got a F250 and are still searching for a source of cheaper consumerables than the main f250 suppliers.
So far I have found oil filters at $22 each. This one is for a Hino truck but also fites F250.
I would appreciate if anyone knows other sources for
fuel filters, air filters, drive belts etc.
Carl
Image Could Not Be Found
Reply By: Member - Boeing (PER) - Sunday, Apr 11, 2010 at 19:34
Carl, Motherhen will be able to assist as I remember they source parts from the US.
Could be worth MM them.
412570
Reply By: oldpop - Sunday, Apr 11, 2010 at 19:37
Carl
What engine in your F250
Oldpop
412571
Follow Up By: Member - Carl- Monday, Apr 12, 2010 at 06:55
Sorry, Yes I should have mentioned it is a 2006 with a 7.3 engine.
682651
Reply By: KyleF250 - Sunday, Apr 11, 2010 at 20:20
be careful on your belt size - there is 3 different sizes for the 7.3lt
if you put cav 296 filter between your
tank and pump it'll save your main filter and save your pump!
412578
Follow Up By: Member - Carl- Monday, Apr 12, 2010 at 07:00
Thanks Kyle,
Off the top of my head I'm not certain about a cav 296 filter. I take it, itis a in line filter that you just insert along the
fuel line?
cav 296 is this a brand name or a part number?
Carl
682653
Follow Up By: Member - Carl- Monday, Apr 12, 2010 at 07:01
Rodger that about the belt. I might just pay extra for that as it will not be a often used item. (hopefully).
682654
Follow Up By: KyleF250 - Tuesday, Apr 13, 2010 at 11:30
cav 296 is a common filter part number,most brands avail for this one. i use it with the glass
water separator mounted in front of
tank in chassis rail. i'll take pic of my for you this week.
i use the k&n air filter
682773
Follow Up By: Member - Carl- Tuesday, Apr 13, 2010 at 11:42
Thanks Kyle, a picture says 1000 words. I went looking for the
fuel filter and could not find it. Only after getting a spare and looking at it did I know where to look. Unusual filter. One would not like to be replacing them everyday.
Interesting learning how each new vehicle works that I get. I had all my
tools down pat for the 200 landcruiser and now everything is back to imperial again.
682774
Reply By: Member - William H (WA) - Sunday, Apr 11, 2010 at 20:37
Try british parts in Kewdale WA.......Cam...08 9470 6668.
This place will send it out by courier to your door step,they can get any part for your car and 4WD........i get my Toyota oil filters and
fuel filters from them,and they charge me $4:90 to send it to me by courier to Bunbury,you will be supprised by their prices.also on Ebay.
Cheers for now...Williamh...Bunbury...WA.
412582
Reply By: Ray - Sunday, Apr 11, 2010 at 23:04
I get my parts and filters for my F series from the States mostly. For my 97 F350 I saved 5 or 600 dollars on
water pump,vacuum pump and idlers + hoses etc over going local and that was air freight included.
For my 09 F350 I bought filters from the States a week back at around half freight included. Ordered them Sunday evening and they arrived at my door Friday morning. I used Rock auto's online store.
412597
Reply By: On the Run - Monday, Apr 12, 2010 at 12:22
As a F250 owner and with the Aus $ so good at the present if you buy in bulk from the USA there are some great savings.Oil fitlers x 12 $20 (purchased Feb 2009) each includes freight.--- (today,s price $17.95) As we are fulltime on the road i order in bulk and pack some with us and the rest sit at home till we go past next time or just get them sent to me where ever we are if I need to. Powerstoke.com is ok to use,autowarehouse,dieselhouse etc ,but there are heaps of others just google F250 parts do a bit of homework and save the dollars
412629
Reply By: Member - Carl- Monday, Apr 12, 2010 at 16:53
Thanks everyone for all that info.
Very helpful and has saved not only money but time looking.
412656
