insect screen
Submitted: Thursday, Apr 15, 2010 at 10:28
Member No 1
is fitting 50% shade cloth in front of radiator but behind grille on 100 series a safe temporary thing to do keep the locusts out?
Reply By: Member -Signman - Thursday, Apr 15, 2010 at 11:26
If it's only going to be temporary- why not mount it in front of the grille? Probably easier to install and easier to clen if required !!
412997
Reply By: Dave(NSW) - Thursday, Apr 15, 2010 at 11:32
ARB sell insect screens for radiators but say not recommended for turbo diesels, But I can't see a problem if you keep an eye on the amount of bugs building up on it to ensure a good air flow through it.
Cheers Dave..
412999
Reply By: Member - Alan H (QLD) - Thursday, Apr 15, 2010 at 11:51
I have a piece of shade cloth wrapped around the centre section of my bullbar. My scanguage only shows the slightest increase in temperature Max of 1 degree.
I find it much easier to clean out there and allows plenty of air to get to the grill other than the direct full frontal air which is where the insects are.
Seems to work for me.
413001
Follow Up By:- Thursday, Apr 15, 2010 at 19:44
interested in your scangauge details uses cost where bought from etc
683086
Follow Up By: Member - Alan H (QLD) - Friday, Apr 16, 2010 at 07:10
Scanguage II is about $200 from Wooders Garage. They have an online
shop and service is great.
683146
Reply By: Member - Graham H (QLD) - Thursday, Apr 15, 2010 at 12:33
Toyota specifically recommend you DONT put them on a TD.
I had one I bought at Soopercrap for $18 and it fitted over the bullbar.
Cable tied it to top of bar and an ocky strap at the bottom corners to wherever I could find under the front
Kept the insects off the radiator and still let the air in.
I had taken the plastic pieces out of the inner guards to induce better airflow when we were in the west in 40+ heat.
Seemed to work as engine temp didnt go up much in view of the heat we were travelling in
413005
Follow Up By: Richard W (NSW) - Friday, Apr 16, 2010 at 07:30
I also read that in the sales material however I had what Toyota call an Insect Screen fitted to the vehicle when new. The vehicle has done 180,000 KM with about 50% outback touring without any dramas.
683147
Reply By: bobsabobsa - Thursday, Apr 15, 2010 at 12:38
G/Day No. 1,
I have turbo LC 2006 Sahara , I Know you asked for shade cloth.
I have been using the flyscreen, purchased the copper or aluminium stuff not the nylon, as the metal stuff can be bent around pipe etc and it will stay there.
Just come across the
Hay Plain and the grasshoppers were bad, it stop them from buggering up the radiator and condensor, etc.
I just feed it behind the grill, and bent it around the bottom, as the condensor is a bit exposed on the corners, so I think it might protect that a bit from stones as
cheers bob
413006
Follow Up By: Fab72 - Thursday, Apr 15, 2010 at 13:03
Bob...Agree with you. I keep a bannister brush under the
seat to give it a quick brush down when ever I stop.
Went to Parachilna for a day trip/Sunday lunch last weekend. Car was covered in the little blighters.
683038
Follow Up By: Member No 1- Thursday, Apr 15, 2010 at 14:38
thanks for latest update Bob ...and Fab72
i just been down to mitre10 and picked up some fibreglass flyscreen
i intend to cable tie it to the front of the bull bar in front of the radiator
am going to
Canberra and back to
Adelaide this weekend and being cool I dont think i should have overheating problems to contend with..or at least thats is what I hope
683045
Reply By: GerryP - Thursday, Apr 15, 2010 at 14:32
I have a temporary one made from shade cloth which I use primarily for when I go through a lot of spinifex. Should work equally
well for locust plagues.
It fits over the front of the bull bar and extends under and past the radiator. Have not noticed any problems thus far, mind you, when using the screen through spinifex, I'm generally traveling at a slower rate.
Gerry
413013
Reply By: vk1dx - Thursday, Apr 15, 2010 at 20:32
Have a look at thread 77701.
I made a stone guard and simply attach a bit of fly screen or shade cloth to the center section in front of the radiator with cable ties whenever bugs are around.
It saves the radiators from clogging and those expensive lights from being smashed when being overtaken by other cars or when just sitting there getting pummelled by stones waiting for a road train to go by.
Worth every penny of the $60 I spent.
413061
