Fuel for thought.........
Submitted: Thursday, Apr 15, 2010 at 15:31
Member - Oldbaz. NSW.
When taking off in the newly aquired Jack in 07 for another
Kimberley trip, with
C/t on behind, 4 adults aboard, fridge full of coldies, (you know the feeling).......
We tooled along to
Balranald at 110kph & a bit more, & got a rude shock when
fuel use was about 19L/100. Cant handle that....we cry....plan B....stay under 100
kph. Result
fuel use drops to 15L/100....that's better. Have been away a couple of times since & have no trouble getting that or better.....by staying under 100 kph.. The only bolt on of any significance to Jack is a long range
tank...140L.
Decided to run it out recently to get true range, non towing , & managed 1020 KM before light came on. Filled up with 120 L. I make it 11.7 L/100.....from the
dreaded 3.5 V6....and auto to boot. Same criteria....stay under 100 kph.
This "lightfooting it" works.....
Now for the car.....1994 Peugeot 405 auto......filled up with 65 L for 1000 km.
That's 6.5 L/100....that I can handle !!!. Both vehicles were not driven to achieve min
fuel use...just cruised at 95/100 kph with gentle acceleration.
The moral of the story....slowing down will save you big
fuel dollars..........
but we all knew that anyway, didnt we ? :))).......oldbaz.
Reply By: Member - Ian W (NSW) - Thursday, Apr 15, 2010 at 16:41
Hey Old Baz,
You got it wrong! Should drive as fast as possible, that way the trip takes a lot less time therefore less
fuel used.
Sheesh! Some of you blokes need to think things out a bit.
Look at summer and winter days. In summer the days get hot and expand, in winter they get cold and contract. Therefore the days are longer in summer than winter. Simple when you think about it.
Ian
413029
Follow Up By: Member - Oldplodder (QLD) - Thursday, Apr 15, 2010 at 16:50
Yep, got to get there before the
fuel runs out, so as fast as possible. :o)
683057
Follow Up By: vk1dx - Friday, Apr 16, 2010 at 04:06
Its also better to only travel in a southerlly direction. Then you can just put it in idle and run downhill all day!!! No
fuel usage at all.
683138
Reply By: Member - William B (The Shire) - Thursday, Apr 15, 2010 at 16:45
Hi oldbaz,
We just came back from a trip to
Lightning Ridge towing an old Viscount camper with the '99 3.0 td Jack.
Cruising along at 100 to 110 kph I could just about see the
fuel gauge going down. 16.5 l/100
Decided to do no faster then 90 on the way back from
Mudgee and as yet have not filled the
tank but just on how far the guage has dropped I can tell that it is a major difference.
Another plus is that you dont feel as stressed after the drive.
As I saw on a sticker on a caravan the other day,
"if you wanted to be in front of me you should have left earlier"
William
413030
Follow Up By: Trevor R (QLD) - Friday, Apr 16, 2010 at 09:28
Last towing trip out west saw my
fuel usage at 23.5lt/100km so I dropped back from 140 to 120kph and
fuel came back to a respectful 20lt/100km. If you want to save on
fuel then get a t/d rice bubble (like a VW polo) and pack the tent. Plenty of vehicles returning greater than 10k/lt at the moment but I still can't go past my 4.2 dinosaurs that keeps on keeping on.
The
sign on the back of my van would read "if you want to be in front you should be driving this rig hahahahha".
All fun, Cheers,
Trevor.
683168
Follow Up By: Member - Oldbaz. NSW. - Friday, Apr 16, 2010 at 10:15
I'll stick with William, Trevor, the idea of towing at 140 kph ,or even 120 does
nothing for my heartrate & even less for
fuel usage. I'll wave as you tootle past
of course...:)))).......oldbaz.
683183
Follow Up By: Madfisher - Saturday, Apr 17, 2010 at 14:14
Gees Trevor the
wheels of the ct would not have been touching the ground lol.
Dont mind sitting on 140 in a work xr6 or similar, but sit on 95 to 100 towing thank you. Just done 454 ks towing my boat to 69l which I work out to 15.19l/100, most siting on 100 with a few ks of very slow crawling in high range first. This like baz is in a Jack 3.5, but manual.
Cheers Pete
683377
Reply By: Tonyfish#58 - Thursday, Apr 15, 2010 at 16:55
WITH GREAT POWER COMES MUCH
FUEL :-)
Jacks will do that to you - but they are great to cruise in
Cheers Tony
413032
Follow Up By: Member - Oldbaz. NSW. - Thursday, Apr 15, 2010 at 17:16
You betcha, that noise they make when you hoof em can be a bit hypnotic
for sure..........oldbaz.
683066
Follow Up By: Madfisher - Thursday, Apr 15, 2010 at 21:06
Especially when you remove those y piece restrictors Baz, but its not unpleasant just sounds like it means business,
mine you Sal says I am not fiddling with hers. But I have wound the torsion bars up a tad on hers to remove that floating feel. The whole side of
mine got wiped out today while parked in the street at work. About $4000 worth of damage.
Cheers Pete
683096
Follow Up By: Member - Nev (TAS) - Thursday, Apr 15, 2010 at 22:59
Sheeze that is bad news Pete, hope the responsible person didn't do a runner. Got 10l/100km out of my 3.0td the last time I drove up to
Launceston and back through the lakes.
Nev
683112
Follow Up By: Member - Oldbaz. NSW. - Friday, Apr 16, 2010 at 08:54
Pete, sorry to hear about that...hope they restore to good as new. The
inconvenience is a bugger...cheers...oldbaz.
683162
Follow Up By: Madfisher - Saturday, Apr 17, 2010 at 14:06
Thanks Chaps, thank god he left his details, turns out I knew him. Its going to the panel beaters where my brother works so they should do a good job.
One of the perks of my job is their should be something in the yard of an evening to go home in, as long as its not the bosses new x5lol. Most likely end up with a ex
mine hilux, but we have a couple of the latest Prados mmmm.
Cheers Pete
683376
Reply By: Member - Andrew (QLD) - Thursday, Apr 15, 2010 at 17:07
Maybe you should be towing the CT with the Peugot. LOL
Andrew
413035
Follow Up By: Member - Oldbaz. NSW. - Thursday, Apr 15, 2010 at 17:13
G'day Andrew, yes I have done that, no problems on good roads, but the likes of
the
Spring Creek track might test even the mighty Pug....:)))...oldbaz.
683065
Reply By: Madfisher - Saturday, Apr 17, 2010 at 14:17
Slighly off topic Baz but I know it will interest you.
One of the chaps on the Jack
forum brought a 3.5 Jack with 398000ks to be used purely as a
test mule. When dynoed it was down 8hp on new amazing.
Cheers Pete
413282
Follow Up By: Member - Oldbaz. NSW. - Monday, Apr 19, 2010 at 13:49
G'day Pete, been away for the weekend. Those figures do my heart good...I will
probably have too many k's on me to ever get
mine up to that figure but will
keep workin on it. Off through Western QLD in about 3 weeks...water permitting.
cheers......oldbaz.
683635
