Getting Firestone airbags to Pajero NM
Any thoughts on a good place to put the air connectors? I have factory bullbar and factory back step.
Any opinions on whether to go the lift or no lift versions. I don't have any real need to lift so was going to go the no lift.
Reply By: Member - Oldplodder (QLD) - Friday, Apr 16, 2010 at 07:40
On my NJ I drilled 2 holes in the back bumper above the tow hitch, about 500mm apart where the bumper steps back a little, which the NM does not have.
Can you put them on top of the tow bar, in the gap between the tow bar and the bumper?
Ran the pipes from the bags back along the chassis rails to the bumper.
Nice and easy to get to at the rear.
AnswerID: 413110
Reply By: Member - Oldbaz. NSW. - Friday, Apr 16, 2010 at 08:58
I got my local mechanic to fit Polyairs to the rear of the Jack, & on his suggestion
put the air fillers inside the fuel filler cavity. Plenty of room there & not subject to
villains fiddling with them or other damage........oldbaz.
AnswerID: 413121
Follow Up By: Spade Newsom - Friday, Apr 16, 2010 at 11:57
What sort of vehicle did you put them in the fuel cavity.
I would have to drill purpose holes to put them in mine which I prefer to avoid.
FollowupID: 683199
Follow Up By: Member - Oldbaz. NSW. - Friday, Apr 16, 2010 at 12:50
Vehicle is a Jackaroo. Sure, drilling holes was necessary, but unlikely to be able to
locate them without doing that anyway. Another advantage is the reminder you get when fuelling to check pressures regularly..........oldbaz.
FollowupID: 683208
Reply By: GlennD - Friday, Apr 16, 2010 at 09:48
Hows it going,
Just ordered these myself, for a Patrol the only diffenence between lifted and not was a bigger rubber spacer at the bottom.
Remembered reading about people ordering from the States so did some googleing and found some threads with info.
Saved a fair bit of cash , $450+ in Aus , $170(Aus) delivered from the states for the exact same item.
Michigan Truck Springs
These guys were really helpful and replied and shipped promptley ( although I havent got them yet )
hope this helps.
Glenn
AnswerID: 413127
Follow Up By: Member - desray (WA) - Friday, Apr 16, 2010 at 20:34
I bought mine from the same place , no problems been very good.
FollowupID: 683271
Reply By: Markcas123 - Saturday, Apr 17, 2010 at 19:10
Hi Spade
On my NP i fitted the air line to the rear of the mud flaps on each side
AnswerID: 413303
