Warn 10000lb wiring
Submitted: Sunday, Apr 18, 2010 at 15:12
ThreadID: 77816 Views:3085 Replies:1 FollowUps:1
The Solenoid on the winch wind in has an intermittent fault. I want to know if I swap the F1 and F2 terminal on the winch motor will that swap the intermittent fault to the wind out.
I understand the remote should work in reverse.
I just need a temporary repair till I get home. I can do without wind out but will need wind in.
Reply By: Member - Christopher P (NSW) - Sunday, Apr 18, 2010 at 22:48
Basics to finding intermittent faults is to check cables connectors, if you go over these qwith a fine toooth comb you might find the problem, i hope this helps.
don't know much about the winch thing. My sparky always said for me to go over everything before i disturbed him.
good luck
AnswerID: 413502
Follow Up By: Members - Bow & Nan - Tuesday, Apr 20, 2010 at 14:43
Thanks for the answer.
I had already checked the connectors , reversed F1 and F2 and it reversed the winch.
Wind in works OK now.
FollowupID: 683738
