2.8 td from NJ into NH pajero....will the motor fit?
Submitted: Tuesday, Apr 20, 2010 at 21:46
ThreadID: 77885 Views:3227 Replies:2 FollowUps:0
will the 2.8 fit in the nh fine, im assuming u=it will, think its all the same running gear..... any thoughts?????
Reply By: Madfisher - Tuesday, Apr 20, 2010 at 21:55
Not a Paj expert , but I do know the NJ had a 2in body lift to accomdate the 2.8, Think it needed a stronger gearbox because of the extra torque, but someone on the Paj forum will know.
Cheers Pete
AnswerID: 413717
Reply By: Member - Oldplodder (QLD) - Wednesday, Apr 21, 2010 at 17:03
Depends what NH you have, and what you have in the NJ to swap over.
Mine is a NH 2.8. - 4M40 block.
Has a 20mm body lift ex factory (to fit the bigger gearbox and it just fits), and the heavier gearbox and diffs same as the 3.5l V6 petrol.
If you have a 2.5 diesel, or 3.0l V6, not the right gearbox and diffs.
AnswerID: 413790
