WSiring Diagram for HDJ79 Traytop
Submitted: Thursday, Apr 22, 2010 at 09:45
ThreadID: 77916 Views:5152 Replies:2 FollowUps:6
G'Day
Recently retired my 75 series troopy only a baby at 406,000 KM..!! and bought a 79Series traytop. Want to fit a kill switch but need a wiring diagram ...dont want to stuff up the electronic "stuff" ...didnt have this problem with the troopy..!!!
Reply By: Member - Doug T (NT) - Thursday, Apr 22, 2010 at 19:24
send me an email and I'll send a wiring diagram also say what section of wiring you need
AnswerID: 413935
Follow Up By: Rob - Thursday, Apr 22, 2010 at 21:25
G'Day Doug
The whole lot would be nice...!!
But failing that engine control & oil pressure switch (not gauge sensor) should do it. My email is rob.605028(at)gmail.com
Many thanks
Rob
FollowupID: 684169
Follow Up By: Member - Doug T (NT) - Thursday, Apr 22, 2010 at 22:02
Rob
No that's not the way to add an email address, you gotta use @ , not at.
FollowupID: 684177
Reply By: Member - Phil G (SA) - Thursday, Apr 22, 2010 at 19:32
Gday Rob,
No response so far - I don't know anyone who's done it. I liked the fact that my 79series had no immobiliser - one less thing to go wrong out bush.
But an old fashioned switch in line with the starter motor solenoid wire would be the simplest thing and wouldn't affect anything else.
I'd guess the other option if you want it to crank but not start is the fuel cut solenoid on the pump. But I don't know enough about it. Might get an answer from LCOOL if you don't get an answer here.
phil
AnswerID: 413936
Follow Up By: Rob - Thursday, Apr 22, 2010 at 21:31
G'Day Phil
Unfortunately living near the big smoke....theft prevention is a way of life...!!
The beauty of fitting something yourself ...is you can be sure you know how to bypass it if there is a problem. Also it makes it that much harder to find if your trying to pinch the vehicle...cos it aint "standard"..!!
I had thought of the fuel cut out - but am not sure if that will bother the EFI box. On the Troopy I had a switch on the oil pressure switch (not the gauge sender) it would run for 5-10 seconds then die...was connected to a 1/4 inch phono plug near the ignition switch - no plug...no go.
Rob
FollowupID: 684171
Follow Up By: Member - Phil G (SA) - Thursday, Apr 22, 2010 at 21:53
Rob,
We don't know whether you've got the V8 or the 6 cyl TD, but I'm guessing its the V8.
If it were the pre 2007 6 cyl TD, I reckon your oil pressure switch cutout phono plug will still work. On the 6cyl wiring diagram, the oil pressure switch wire goes to something called the "oil pressure switch ECU" which I expect cuts the motor with zero oil pressure.
If its the 2007+ V8 then I don't know. I'm just wondering whether Doug knows what motor you've got?
FollowupID: 684175
Follow Up By: get outmore - Friday, Apr 23, 2010 at 07:10
for the amount they cost to get fitted I wouldnt muck around with it myself
all vehicles in WA have immobalisers by law after the local "disadvantaged youths" went overboard on car borrowing in the early 90s
(took mum and das commodore up the hills and burnt it)
the final straw was when one of them ran a light and took out a pregnant lady
now to get a vehicle regod it needs an immobaliser
FollowupID: 684203
Follow Up By: Rob - Friday, Apr 23, 2010 at 10:48
G'Day Phil
I didnt realise the 79 came out with the V8..!!
Mine is the 6 Cylinder - any chance of a scan of that wiring Diagram..??
G'Day Get outmore
As i mentioned before I want to know where its connected and how its doing the isolating...so when things go pear shaped out bush I can be sure that the immobiliser isn't causing the problem. I guess I could buy one and fit it myself but then I would still need the wiring diagram eh...!!
FollowupID: 684229
