CSR realignment between Well 3 and 4A
Hi All
Just thought i'd share the realignment of the route between Wells 3 and 4A, the station has closed the route we last went on that tracked north of the current track.
Sorry the pictures not better it wont let me load the pdf.
RegardsImage Could Not Be Found
Per Mare Per Terram
Reply By: Wayne (NSW) - Friday, Apr 23, 2010 at 20:33
Oggie,
If I am reading the map right, the track no longer goes past White Well.
If that is the case it has been that way for the last 4 years that I have travelled that section.
Wayne
AnswerID: 414070
Reply By: ExplorOz - David & Michelle - Friday, Apr 23, 2010 at 20:53
Can someone email me a plot file for this section so that I can verify our mapping data please - Or can someone that knows please check the treknote and let me know if I need to update the data.
David
AnswerID: 414074
Reply By: Richard W (NSW) - Saturday, Apr 24, 2010 at 06:24
Oggie,
Thanks for the info.
This is an image of the Hema Map I have which appears to show and comment on the realignment.
AnswerID: 414102
Follow Up By: Wayne (NSW) - Saturday, Apr 24, 2010 at 08:36
Richard,
The map shows the original track. It has changed and no longer goes pass White Well or Corner Well.
There are signs to guide you on the bypass which rejoins the main track around Snell Pass.
Wayne
FollowupID: 684329
Follow Up By: Richard W (NSW) - Saturday, Apr 24, 2010 at 09:52
Wayne,
Thanks for that.
FollowupID: 684343
Follow Up By: The Explorer - Saturday, Apr 24, 2010 at 10:58
Yes it looks like the bypass mentioned on the Hema map has been bypassed :)
If you look on Google Earth you can see the track heading east from Well 3 then northwards. Its a bit hard to follow after that.
FollowupID: 684352
