Cape York with a trailer boat
Submitted: Sunday, Apr 25, 2010 at 13:16
Member - Andrew B (NSW)
Hi, I'm planning a trip to
Cape York in July and want to tow a 4m boat with offroad trailer as far as possible. I assume getting to
Weipa would be no problem but can anyone tell me where else on the cape would likely to be accessible with a good trailer? I'm hoping to get out to the islands and reefs near
Cape Melville either from
Cape Melville Nat Pk or from the
creek mouth at Port Stewart, and maybe other spots on the east coast of the cape further north.
Thanks,
AB
Reply By: Dave(NSW) - Sunday, Apr 25, 2010 at 13:48
Andrew,
Some of these guys live up there and could give you all the info you want.
http://capeyorkforums.com/forums/
Cheers Dave..
414213
Follow Up By: Member - Andrew B (NSW) - Sunday, Apr 25, 2010 at 20:14
Thanks Dave
p.s. GQs are the go :-)
684464
Reply By: Crackles - Monday, Apr 26, 2010 at 20:27
With a good offroad trailer you can go almost anywhere. On our Cape fishing trip we had coil
suspension fitted to a standard boat trailer with additional stone & vibration protection added as
well as extra bracing for the engine. We took most side trips to the coast & only had minor problems negotiating around the trees on a few tight tracks due to the long drawbar. The corrugations do cause alot of rubbing on the hull so we padded everything heavily with carpet. The boat was almost floating on the Frenchman's :-)
Cheers Craig..........
Telegraph track.
414383
Reply By: Peter_n_Margaret - Monday, Apr 26, 2010 at 21:16
There is some sand to negotiate and some tight sections around trees on the way to
Cape Melville.
But worth the effort..........
OKA196 Motorhome
414392
Reply By: Tonyfish#58 - Tuesday, Apr 27, 2010 at 14:20
You will have no issues where you have mentioned above - You can also launch at Chilli Beach at Iron Range
Remember a good rock guard for your boat though, you will need it.
414456
