batterie amp hours
hi all i have a question.
if i connect 2 12 volt batteries that are 10amp hours each when connected together will they be 20 amp hours ? thanks
Reply By: Battery Value Pty Ltd - Tuesday, Apr 27, 2010 at 19:38
Hello Zacc,
yes, they'll give you 20Ah when wired in parallel (positive to positive, negative to negative).
Best regards, Peter
AnswerID: 414490
Follow Up By: Trevor R (QLD) - Wednesday, Apr 28, 2010 at 08:31
Hi Zacc,
It is important to follow Peter's method of connecting the batteries. If you connect them in series you will end up with a 24V 10amp battery bank.
Cheers, Trevor.
FollowupID: 684740
