If you tow a camper, trailer or caravan, read on!!!
Submitted: Tuesday, Apr 27, 2010 at 22:04
Michael ( Moss Vale NSW)
I just posted a blog about my mishap with my trailer on the weekend. It was not a good situation to be in but it could have been worse. Its worth a read about spares you should carry if you have leaf springs on you trailer/ caravan.. I found out the hard way. Michael
Reply By: Member - Barry (NT) - Tuesday, Apr 27, 2010 at 22:28
Hi Michael
sounds like you handled it all quite
well, no panic and thought things throughlogically. Ditch Optus is my suggestion no matter how much we despise Telstra at times service is superior in many many
places.
We are on the road in 3 tonne van and resigned to fact we can't carry everything despite the very remote travl we do at times.
On the trailer bit,,, you could have an endless list,,,,, axle/ stub axles; coupling; cross member; mudguards; shackles; shackle bolts etc etc so we have to do what is reasonable to us as individuals, and on case by case basis.
Inspections can help as you alluded to. I've replaced the floor in a 25 year old box trailer twice and 2 cross members due to rust. Whilst in
Adelaide the trailer was used by someone else and overloaded and unknown to me the A frame was cracked on one side. I had a full load for the dump from sister in laws place and jumped on A frame to tie down the load and it felt"springy". A quick inspection revealed it was really springy.
It's off the road waiting for new A frame,,, so you are not alone in having problems.
Best maintained $500,000 prime movers still break down believe me.
Good luck and
well done.
Good of you to raise this important subject though.
414524
Reply By: Motherhen - Wednesday, Apr 28, 2010 at 00:17
Hi Michael
We have twice had failures; both times it was spring hanger bolts on our caravan. In 2008 the back bolts broke and the spring dragged (with Simplicity
suspension, you don't know). We were 90 kms west of
Warburton WA, so fairly remote. We drove back some way and found the brackets, and thought we'd most likely have to go to Kalgoorlie for bolts. Luckily we had the right ones in our bags of bolts. Last year we were in the Davenport Ranges south east of
Tennant Creek NT, only this time it was front bolts, which resulted in the spring curling up under the van beyond repair. We needed out satellite phone and patience, while camped on the road for two weeks. We replaced both springs and all brackets and bolts with genuine parts from the Simplicity factory.
Murphy is always lurking out there to get you!
414539
Reply By: Member - Rodney B- Wednesday, Apr 28, 2010 at 10:42
Know all about your problem
2 years ago on way up the Cape we diverted to
Cape Melville and on the way back I noticed in the mirror that the r/hand wheel was more visible than usual.
U Bolts had come loose resulting in 2 spring leaves broken.
Had a new spring (as you always do) in the trailer but what I didn't check was the shackle bolt size on the new spring. (yep it was too small and didn't have a drill that big) so ended stripping new spring and rebuilding old one. We would have been
well and truly stuck without the spares. Reason it came loose was the U Bolt plate was only 8mm thick and was bending every time I tightened/checked the U bolts. Replaced it with a 16mm plate in
Bamaga and have had no problems since. As a bare minimum you should carry a main leaf, U Bolts and plate on off road trips.
Rod
414566
Reply By: Member - Mfewster(SA) - Wednesday, Apr 28, 2010 at 12:58
It's just impossible to carry everything and you know the bit you need will be the one you didn't bring. One of my handiest investments is quite a cheap, small gadget called a Clamp-it that can be used to do emergency repairs in an incredible range of situations. I have seen leaf springs temporarily fixed with these. You will find them on the web. The usual "I'm not connected to them in any way" disclaimer.
414583
Follow Up By: Member No 1- Thursday, Apr 29, 2010 at 08:17
carrying spares for the car is more important
its hard enough fitting all that in let alone trailer stuff
maybe a bit of wire could have been used as temporary shackles
684831
Follow Up By: Member - Mfewster(SA) - Thursday, Apr 29, 2010 at 10:22
Member No1. That's the beauty of the Clamp-it. A bit of wire can be turned into something really strong; tight and neat. You never need to carry a collection of hose clamps either. My latest use for it was fixing the arms that snapped in a high wind on a market umbrella.
684843
Reply By: Ted G - Wednesday, Apr 28, 2010 at 13:50
Hi Michael
I was once told by someone that travelled around the lap that if he had carried all the spares he needed he would have had to take a 5 tonne truck.
The one thing he regretted not taking was his welder to weld up all the wizbang doors of the backpacker campervans parked next to him.
Regard
Ted
414589
Follow Up By: Member No 1- Thursday, Apr 29, 2010 at 16:11
william and roachie DONT have 5 ton trucks...:))))
684892
Reply By: Michael ( Moss Vale NSW) - Wednesday, Apr 28, 2010 at 17:01
Thanks for the replies everyone, This situation caught me out this time. I have a mechanical background and i have always had the thinking that there is always another way, but in this case without help, there was not! I forgot to mention that both springs are bent, (main leaf) and one of the pads that are welded to the axle to keep the centre bolt on
the springs in position was only held by 2 small dots of weld, the rest of the weld had been broken for some time , indicated by the rust between the broken weld and the axle. This pad broke off also. I also had a Treg hitch so no damage to the Patrol or Trailer "A" frame.
I think as far as a trailer/caravan goes, a spare spring, a set of U bolts and nuts and 2 centre bolts for
the springs would cover most situations with leaf spring
suspension failure.. $130 total for the parts may mean repairing the trailer and on your way the same day, waiting a week for the bits or leaving it behind. Regards Michael.
414604
Reply By: Gazal Champion - Wednesday, Apr 28, 2010 at 17:34
Hi Michael, Looks like it is time for a new undercarriage, you know, springs, axle, seeing as it is bent, and new shackles.
On last holiday (Nov 09) traveling along Thunderbolts Way between
Gloucester and
Walcha, in fact just 12 K south of
Nowendoc I broke a main leaf on the spring on the left back axle on the 2 tonne van which allowed the wheel to rub on the underside of the wheel arch and nearly caused a fire.. No spares of course but that is usually the way. What you do carry is not what you need. Murphys Law!
Luckily I always carry a full set of
tools including long bodied sockets. Any way, found a safe place to pull off a fairly narrow road and pulled the spring off and drove 80 clicks into
Walcha and had a temporary repair done which got us to
Tamworth for replacements. But I have decided to replace all springs because if one went how many more of the four of them are ready to go also.
As you have shown as an example, a cool head can usually get you out of most predicaments, Oh and it helps to have obliging brothers to. I have one also.
Cheers, Bruce.
414609
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Apr 28, 2010 at 18:56
Hi Bruce, Yes , my brother drove the 700 odd kms for which i am greatful. But luck was with me for it to all come together and be out of there 24 hours later on a long weekend. The complete undercarriage will need replacing, one electric brake drum is damaged because of the bent axle and it was time to replace the drums, magnet and shoes soon anyway, its 10 years old. $1200 is close to the mark i think. But i still think if you carry U bolts and nuts and a complete spring (can be bolted under the van) and a couple of centre bolts, you will have covered most bases. regards Michael.
684783
