Steinbauer engine performance enhancer
Submitted: Saturday, May 01, 2010 at 07:24
Member - Alex V (VIC)
We recently installed a Steinbauer chip in our 2008 Nissan Patrol ute and proceeded the following day to do a 5 week trip round Tassie on which all went fine with the vehicle until 2 days before we were due to come home - the engine just could not get enough
fuel to start when we were stationery in a
carpark. RACT came out and we got it going again, no more problems for 130 kms or so, when the same thing happened again - the engine just died and stopped. With any 4x4 club (with whom we were travelling), putting the bonnet up is a magnet and the guys were able to once again get us going. As we were at this stage in a pretty remote place and with motor running, we decided to head back towards civilization and made it to
Launceston without trouble and booked the car into the Nissan dealership. They diagnosed a fault with the common rail
fuel system, some
fuel return valve (this is being typed by the handbrake!) and replaced same at no cost to us as the vehicle is still under warranty. OK, no more problems - we have subsequently done a return trip to Horsham from the Mornington Peninsula and travelled up to Wagga Wagga, some hundreds of kms, before the problem struck again - 3 times in fairly quick succession. On each occasion my husband was able to pump the bulb to get the
fuel through to the engine again and could then restart the engine easily. As we were about to start the
Darling River Run which would take us
miles from assistance, we headed to Dubbo and once again, had the vehicle diagnostically checked by Nissan. The only solution they could offer was the
fuel pump which they said 'might' be faulty and could we leave the car with them for 5 weeks or so while they had it checked. Needless to say we did not accept that option and went on our merry way, experiencing not a minute's problem for the remainder of the trip down the Darling or back home to the Peninsula. A conundrum.
Had anyone else experienced this sort of problem a) with a Steinbauer or b) with a Nissan? We'd be interested to hear.
Reply By: Member - Graham H (QLD) - Saturday, May 01, 2010 at 07:50
First logical thing to do would be to disconnect the chip as it may not be causing the trouble at all.
Do that and go for a run and see what happens.
If it doesnt do it for a week its probably the chip If it dies without it its something else.
fairly easy decision.
414936
Reply By: Member - DAZA (QLD) - Saturday, May 01, 2010 at 07:57
G/Day Alex
We have a 2008 Patrol, and have the Steinbauer Chip installed, have not had any problems at all, have you tried disconnecting the Steinbauer Unit and running the vehicle as normal, not hard to do, or phone the Steinbauer Supplier at
Dalby they can give you some advice.
414937
Reply By: broome time - Saturday, May 01, 2010 at 14:48
i installed a steinbauer chip in a 2005 patrol 6 months ago.done about 6000 klms.never had a problem.gave me more power &touqe, but didnt notice any improvement in
fuel consumtion.
414969
Reply By: broome time - Saturday, May 01, 2010 at 14:49
fuel consumtion.
414970
Reply By: Ranger75 - Saturday, May 01, 2010 at 16:50
If you are having to prime the
fuel pump each time to restart the engine then you have a blockage between the
fuel tank and the
fuel filter.
One obvious cause of this type of problem (apart from a mechanical blockage in the
fuel line) is bacteria in the diesel
fuel causing a gel to form in the
tank, which blocks the pickup, thereby starving the system.
Have you had the
fuel tank cleaned out, and are you using a bacteriacide with each fill of
fuel??
The best product is
Fuel Doctor which is generallly available from
places like
Supercheap etc. (No affiliation here)
Suggest before you start on anything else you get the
fuel tank cleaned out and dose the refill with
Fuel Doctor.
The above from personal experience!!!
414991
Follow Up By: Member - Alex V (VIC) - Sunday, May 02, 2010 at 09:45
Thanks so much for your comments. I think the bacteria is a point that I have omitted to think about and will now do so. It seems to answer a lot of questions. Cheers Alex
685251
