resealing van
Submitted: Sunday, May 02, 2010 at 21:36
ThreadID: 78174 Views:2922 Replies:4 FollowUps:3
I have notice that some of the white sealant across the bottom of the outside walls is starting to have gaps in it. I want to know how to and what to use to reseal it.
Do you take the centre PVC strip out and undo the screws, then pull the trim off. or do you force it down between the gaps?
Do I use caulking compound or a silicone type product?
cheers Shane.
Reply By: Member - mark f1 (VIC) - Sunday, May 02, 2010 at 22:44
hi shane, without actually seeing a pic of the problem i would have a guess and say clean out as much of the old stuff as you can, then refill with white silicone rather than the other types of fillers.You can get bathroom silicone from bunnings but remember to clean the old stuff off before refilling.
AnswerID: 415157
Reply By: Outnabout.. - Sunday, May 02, 2010 at 23:22
I use marine grade Sikaflex in white. Be carefull in applying. It looks crapola if the excess is not cleaned off properly.
AnswerID: 415162
Reply By: Member - Doug T (NT) - Monday, May 03, 2010 at 10:15
I had leaks on my van, I had people saying use this and use that, Sikiflex was one , still leaked, then I remembered back to 1961 when my Dad put 2nd hand roofing on the shed , it had 100s of nail holes in it, he sent me up with a tin of Hydraseal, He sold the property 8 years later and the shed still had no leaks, so I went to a hardware store and to get some, they had Duraseal, basicly the same stuff, my van hasn't leaked since, this stuff is black and if you need to it can be painted over. best applied with an old knife, petrol removes it from hands.
Image Could Not Be Found
AnswerID: 415190
Follow Up By: Member - DAZA (QLD) - Monday, May 03, 2010 at 14:47
Geez Doug, plumbers call that stuff Abyssian Solder,or Black Jack, lol lol.
FollowupID: 685393
Reply By: Tenpounder (SA) - Monday, May 03, 2010 at 17:43
Hi Shane. I read somewhere that it's a waste of time, and makes a mess, if you try to run a bead of silicon along trim or window frames. So, when I had to do mine, I progressively removed each window frame, the door frame and the corner strips, cleaned out the old sealer, and applied fresh sealer. But no, I didn't use silicon sealer, I used a non-drying industrial caulking sealer, to allow for the flexing that van bodies have to cope with.
While it seems to have worked well, it was a lot of hard work, so be warned!!
Does this help?
AnswerID: 415239
Follow Up By: Member - shane (SA) - Monday, May 03, 2010 at 20:02
Thanks all, the strip I need to seal is along the base of the walls on the out side.
It has aluminum edging with a vinyl strip in the middle with screws under it, where it meets the walls or cladding there is starting to show signs of the old sealer cracking.
cheers shane.
FollowupID: 685432
Follow Up By: Tenpounder (SA) - Monday, May 03, 2010 at 20:16
OK. So, as I suggested above:
lever off the vinyl strip, using a screwdriver to start;
remove the screws;
pull away the aluminium extrusion;
clean up the surface below (and repair any deeper damage to the frame etc);
run a new bead of sealer along the screw line;
refit the aluminium extrusion;
wipe off the surplus sealant with solvent;
have a coffee;
refit the vinyl strip.
FollowupID: 685435
