Tuesday, May 04, 2010 at 22:43
You start
here to select the maps you want to download.
The map type to select is ECW. These contain the information OziE needs to create the .MAP files. These are the files OziE uses to goereference the files that actually contain the mapping information. You will probably want to convert the maps to from ECW to the format OziCE prefers to use (ECW will work but require a lot of processor power.) The conversion program, called IMG2OZF is available free from the OziE web site.
To do this you need the PC version.
You are now probably totally confused - sorry. It can all be a fairly steep learning curve, but
well worth it once you understand how it all works. There is a lot of info in the OziE help files, and also the OziE and OziCE discussion groups.
Good luck
685546
