Nissan Patrol Overheating
Submitted: Monday, May 03, 2010 at 09:27
ThreadID: 78186 Views:5744 Replies:4 FollowUps:14
G'day
I have a 2001 Nissan Patrol 4500 Auto dual ULP & LPG
When towing my Windsor 21.5' van using petrol the vehicle overheats: this can be when idling or towing on flat roads at 85k's (around 2000 revs). On hills I turn off the OD button and also switch to power drive.
The car has been checked by tow mechanics one in Hughenden and one in Charters Towers. Both said everything was working well.
Anyone had the same problem or do have some suggestions
PeteM
Reply By: Fab72 - Monday, May 03, 2010 at 09:42
Does it overheat under the same conditions when running on LPG?
AnswerID: 415182
Follow Up By: Member - Peter M (QLD) - Monday, May 03, 2010 at 12:00
Does not overheat when on LPG
PeteM
FollowupID: 685369
Reply By: Keith R (Townsville - QLD) - Monday, May 03, 2010 at 10:32
Has had similar issue and found the inlet to the water pump had a piece of corroded hose spring lodged which restricted the flow of coolant. Good luck
Keith
Oldy but still a Goody
AnswerID: 415194
Follow Up By: Member - Peter M (QLD) - Monday, May 03, 2010 at 12:04
Thank you. I will check that out.
Do you have the name of a good Nissan Patrol mechanic in Townsville?
regards
PeteM
FollowupID: 685370
Follow Up By: Keith R (Townsville - QLD) - Monday, May 03, 2010 at 12:39
I use TMShttp://www.tms-mechanical.com.au/ when I don't want to do it myself. Although they don't "specialize" in 4WDs they seem to be very good. Just talk to Peter and go from there.
Keith
FollowupID: 685375
Follow Up By: Member - Peter M (QLD) - Monday, May 03, 2010 at 13:25
Thanks Keith
I will book the Patrol in for the end of the month when I will be back in Townsville for a couple of weeks
PeteM
FollowupID: 685380
Follow Up By: howesy - Monday, May 03, 2010 at 14:04
As he said corroded springs in the lower hose and they can also allow the hose to gradually suck in closing off and restricting flow. Most wouldnt notice this you have to give it constant revs over 2000 on a hot motor while watching the hose. Also has it got thermos on that vehicle or a viscous hub as this could be losing a bit of oomph and not locking up tight enough. Also if its only petrol get your exhaust gases checked under load on a dyno it may be leaning out at certain revs.
FollowupID: 685388
Follow Up By: Dave(NSW) - Monday, May 03, 2010 at 23:16
If it's the radiator hose why doesn't it do it when running on gas?
GU RULES!!
FollowupID: 685455
Follow Up By: howesy - Tuesday, May 04, 2010 at 00:01
hence the end bit about the dyno and exhaust gasses if he is convinced it only happens on petrol
FollowupID: 685460
Reply By: Member - mazcan - Monday, May 03, 2010 at 11:10
hi peter m
is there a build up of insects/grass hoppers /gass seeds etc on the aircon and or radiator cores
have you checked/changed the thermostat
maybe the vans to heavy for it
AnswerID: 415199
Follow Up By: Member - Peter M (QLD) - Monday, May 03, 2010 at 13:23
Thanks mazcam
i will check out the thernmostat, the air con & radiator cores are OK
PeteM
FollowupID: 685379
Follow Up By: Member - mazcan - Monday, May 03, 2010 at 13:44
hi
peter m
also if your patrol still has std exhaust system you will find it will run a lot cooler
and pull better if you install a larger exhaust/muffler system 2.5" or 3"depending on whether its a 3ltr or 4.2 engine
a larger exhaust allows the engine to breath more freely and get the spent heat away in a free flow manner i'm sure there are other patrol owners out there who will confirm this
this improves most vehicles no mater what brand
FollowupID: 685384
Follow Up By: Member - Peter M (QLD) - Monday, May 03, 2010 at 13:54
I will talk to the mechanics in Townsville that Keith suggested re a new exhaust system
PeteM
FollowupID: 685385
Follow Up By: Keith R (Townsville - QLD) - Monday, May 03, 2010 at 14:04
Pete M
Yes exhaust enlargement dose make a difference but if the over heating is something that has become abnormal then please investigate and corret before masking the issue with mod's. TMS will advise but Parkes Exhaust will do the work
(they did my Patrol) for around $1-1.5k
Keith
FollowupID: 685389
Follow Up By: Steve Ellis - Monday, May 03, 2010 at 15:04
Peter. I have the same vehicle and had the same problem. New radiator. No more problem. Keep OD of at all times when towing. Regards Steve
FollowupID: 685396
Follow Up By: Members Paul and Melissa (VIC) - Monday, May 03, 2010 at 20:25
my mates GQ had a similar problem and it also turned out to be the radiator. replaced it and no more overheating.
FollowupID: 685440
Reply By: Member - Bucky - Tuesday, May 04, 2010 at 05:44
PeteM
Generally auto's kick down on hills, when revs drop a little, or things start to strain.
Do you manually pull down gears ?
I am sort of wondering if there is a reving problem, like not enuf !
Mostly I keep 2300 - 2500 rpm on hills, and do not get overheating.
Things get hot in my patrol, when I get lazy, and hang on a little longer to the gears.
Bucky
AnswerID: 415288
Follow Up By: Member - Peter M (QLD) - Tuesday, May 04, 2010 at 07:54
Thank you Bucky and everyone else that have offered advice/help
When approaching steep hills/inclines I normally switch over to ULP as I feel that I don't get enough power from gas.
We are leaving tomorrow to travel up to the Tablelands/Innot Hot Springs so I will switch the OD offand keep the revs up and do a bit of manual gear changing.
The power button being used seemed to help too
Oncde again trhanks
PeteM
FollowupID: 685468
