Microwave Ovens
Submitted: Tuesday, May 04, 2010 at 10:10
ThreadID: 78209 Views:5650 Replies:5 FollowUps:4
We are considering buying a small microwave oven to use in our camper trailer at powered sites. Does anyone have any suggestions or experience in this area
Joma08
Reply By: Member -Signman - Tuesday, May 04, 2010 at 10:17
We got a little cheapy from Aldi a while back- and use it in the campervan (when power is available)...works great !!
Remove and pack the glass turntable when not being used..
AnswerID: 415310
Follow Up By: Joma08 - Tuesday, May 04, 2010 at 16:42
Gidday,
Thanks for your prompt response. A couple of questions. Is yours an electronic push button or operated by knob? What is the power input and output? and finally the size.
Thanks for your help
FollowupID: 685500
Reply By: Who was that again? (Vic) - Tuesday, May 04, 2010 at 10:50
Ours just failed. Screws fell out of the fan motor, and generator overheated in the microwave. There are better options.
AnswerID: 415313
Follow Up By: Member -Signman - Tuesday, May 04, 2010 at 10:53
What brand was it John ??
FollowupID: 685475
Follow Up By: Who was that again? (Vic) - Tuesday, May 04, 2010 at 11:09
Sharp
FollowupID: 685477
Reply By: Member - DAZA (QLD) - Tuesday, May 04, 2010 at 11:05
G/Day Joma
We have one in the Van, its a Convection type, the Cook uses it quite often mainly for nukeing vegetables or reheating leftovers ect, it's built into the cupboard, if it ever dies it would be a hell of a job getting it out lol.
AnswerID: 415317
Reply By: Rod E B - Tuesday, May 04, 2010 at 11:43
Aldi had one on special about a month ago
hotplate on top
microwave oven
which was also normal oven and griller
maybe no help now , but such an animal exists
Was going to look at it for our caravan , but it was a whisker too big
AnswerID: 415320
Reply By: Member - joc45 (WA) - Tuesday, May 04, 2010 at 12:30
Ok, I'm open for discussion on this one, and I preface this by saying I don't use one -
my feeling is that a small "inverter" type microwave will be less stressful on a 12v/240v inverter. Simply coz it regulates the power to the magnetron (mw generator) at a high frequency compared with the slow on/off power control of the more conventional (not convectional) microwave ovens. With the slow on/off power control, the 12/240 inverter is going from high power to nearly zero power repeatedly - it has to keep trying to regulate its 240v output under duress.
Unless you're cooking at 100% power all the time, then there is no issue.
My experience with a particular 12/240v inverter was that pulsing the appliance on and off repeatedly caused the inverter's early demise. Several times.
Ok, now shoot me down...
And I've seen dedicated 12v microwave ovens for sale, but they're many times the cost of a cheap conventional oven.
Gerry
AnswerID: 415325
Follow Up By: Ozhumvee - Tuesday, May 04, 2010 at 13:49
You will never run a 240v microwave on an normal camping type inverter, they pull a huge current in pulses, even the "inverter" type pull big current in short bursts. We tested about half a dozen small ones. Typical amp draw on 12v was up around 70 amps, there is a reason 12v microwaves cost so much ;-))
FollowupID: 685489
