Cleaning Alloy Bar
Submitted: Tuesday, May 04, 2010 at 12:07
Tony @ Naomi
Hi, any idea on which product to use to poilish alloy bullbar, I have tried ordinary polish but makes no diference,
Thanks, Tony
Reply By: Member - Duncs - Tuesday, May 04, 2010 at 12:47
Tony,
I am assuming you have mud stains on the polished alloy. If so you have my sympathies.
From my limited experience there is no substitue for a cutting polish and lots of elbow grease. Of course having cut the stain off you need to re-wax the bar to keep that pretty polished alloy looking its best.
If you look at the pictures on my profile page you will see the ultimate long term solution to the problem.
The black, power coated steel is so much easier to keep clean.
Duncs
415326
Reply By: Mark S (cns) - Tuesday, May 04, 2010 at 12:55
Autosol. buy at any auto
shop
415329
Reply By: Fab72 - Tuesday, May 04, 2010 at 12:55
A tube of Autosol and a huge tube of Elbow Grease.
415330
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, May 04, 2010 at 12:58
Cutting compound and elbow grease will do the trick.
Dave
415331
Reply By: Member - Stephen L (Clare SA) - Tuesday, May 04, 2010 at 14:01
Tony
Like above, Autosol and your alloy bar will come up like new.
415336
Reply By: Member - Ian F (WA) - Tuesday, May 04, 2010 at 15:12
Try "The Original Purple Metal Polish" by California Custom.
It has its own metal protectant and a lot of truckies use it.
Ian
415341
Follow Up By: Member - peter h (SA) - Wednesday, May 05, 2010 at 07:58
I use this product. It does a cut job and you dont need much or any hard work to get a great shine
685557
Reply By: Member - David C1 (VIC) - Tuesday, May 04, 2010 at 15:40
Hi Tony give a product called purple a try. You should be able to purchase from a truck parts supplier.
415346
Reply By: Member - Dazza- Tuesday, May 04, 2010 at 15:44
Tony,
Duncs is on the right track, but you don't have to go steel. I got tired of polishing alloy and found that it takes powdercoating just fine.
Chers .... Dazza
415348
Reply By: Member - Beemer - Tuesday, May 04, 2010 at 16:03
Got to agree with Ian F,
Use Purple, I use this on my bikes headers and it is brilliant.
Beemer
415351
Reply By: CraigB - Tuesday, May 04, 2010 at 17:10
As others have said Autosol. Either that find someone woi owns a Harley and ask them. Have you ever seen a dirty Harley Davidson?
415364
Reply By: Member - Brian (WA) - Tuesday, May 04, 2010 at 18:10
You could try Ali Brite.Think you can get it from Supercheap.
Be careful with it
Brian
415375
Reply By: Fatso - Tuesday, May 04, 2010 at 18:25
If you don't want it to shine but have an even finish just buy a roll of steel wool & buff it all over with that. Make sure you rub in the same direction to get a good even finish. Use some soap &
water with the steel wool as
It is nowhere as sexy looking as a shiny polished bar, but it is easy.
It is reasonably flat in gloss.
If you don't like that go for one of the fine metal polishes. As the post before pointed out, there is no shortage of them on the market.
415381
Reply By: Member - Rob S (NSW) - Tuesday, May 04, 2010 at 19:36
