2005 Sahara
Submitted: Wednesday, May 05, 2010 at 09:55
Werribee
Can anyone suggest where in
Melbourne I can get my Sahara Cruiser frontend aligned properly.
Vehicle to date has had easy 85,000 Klm life with caravan towing for around 10,000K of that, no off roading.
Driving vehicle feels like driving on the top of a fence and wanders either side.
Outside of edges of tires are feathering so something is not right.
Front end has been aligned by an ARB reccommened front end specialist, Toyota and Pro Axel all without improvement.
Reply By: Mr Pointyhead - Wednesday, May 05, 2010 at 10:21
Is your tyre pressure too high ? That could contribute to your symptoms ?
Otherwise try
http://www.auto-craft.com.au/
Darren at Auto-craft has a lot of knowledge with these things .
415479
Follow Up By: Werribee - Wednesday, May 05, 2010 at 10:32
Thanks,
Ive tried different pressures from 38 to 50 no change.
I'll contact Darren.
685571
Reply By: nomadoz - Wednesday, May 05, 2010 at 14:47
Hi Werribee
I had the same problem with a hilux, by the time covered 15k been twice back to the dealer, each time getting worse.
Taken to Pedder’s in
Darwin, now 15k on still spot on
415509
Reply By: Members Paul and Melissa (VIC) - Wednesday, May 05, 2010 at 19:41
i think you will find it is your rack ends are worn which severely affects the alignment when driving. have this rectified then get a wheel alignment and all will be good. if you are a member i can recommend someone via PM in
geelong who knows these 100 series very
well
415551
Follow Up By: Werribee - Thursday, May 06, 2010 at 09:23
I'll get them checked, but 6 months ago when Pro Axle did the alignment "they said" they checked for any wear and everything was OK.
It's due for a service I'll have Werribee Toyota check them out for me.
685694
Reply By: Member - MUZBRY(Vic) - Wednesday, May 05, 2010 at 20:30
Gday
Are they the original tyres? If so , put new tyres on.
Murray
415559
Reply By: Member - Clive G (NZ) - Wednesday, May 05, 2010 at 20:46
Had the same thing with my 100s VX. The thing wobbled and swayed all over the place especially a lower speeds, and the front tyres were feathering on the outer shoulders. It felt like all the steering joints were worn, but it only had 80K on the clock.
Tried everything including a wheel alignment, but nothing seem to make any difference. Finally put the
wheels off my K/Karavan on and borrowed two more for a trial. It all went away. It was the tyres (Grandtrek 22) with about 35K on them, and they looked just fine.
Changed all four tyres to Bridgestone Dueller AT and have never seen the problem again.
Would be very surprised if your rack ends were worn at 85K.
Clive.
415565
Follow Up By: Members Paul and Melissa (VIC) - Wednesday, May 05, 2010 at 21:36
mine are and its only done 77k and it is a common problem
685654
Reply By: Werribee - Monday, May 10, 2010 at 09:57
Thanks all for your suggestions.
I have it booked in Saturday at Auto Craft in
Geelong for them to give it the once over and hopefully recommend corrective solution.
I'll let you know outcome and if it's fixed for good.
416086
