leaking caravan boot
Submitted: Sunday, May 09, 2010 at 10:04
andy mitchell
hi all
we purchased a new caravan in November 09 (windsor genesis gc611) and have had the van back to dealer due to the front boot leaking. the dealer said that they all leak and that there was nothing that they could do, other than placing a grated mat of some thickness in the bottom to stop equipment laying in
water before if drains out of the drain holes in the base of front boot.
the
water is draining from the roof of the van running down the front and then some how forced over the small internal lip that surrounds the opening to the boot. things like our
camp chairs seem to be damp and growing mould in the pours of the fabric.
our van unfortunately is stored out side and have notice a small amount of
water entering and a constant damp since rain has arrived (southern victoria).
my question is has any one had similar problem, and how did they go about fixing it.
kind regards
andrew
Reply By: PeterInSa - Sunday, May 09, 2010 at 10:28
Andy,
Firsts thing I would do is confirm whether the
water is coming from the Boot Opening or elsewhere. ie a front window/seal above the boot, or roof. To do this I would stick a piece of plastic more than the width/height of the boot over the boot with the top of the plastic say 50mm above the boot, stick dowm with Sliver plastic tape ,would stick down both sides as
If after rain the boot is still dry its a boot problem, otherise it could be the window seal above the boot leaking (as in our case). would then replace the seal etc.
If its a boot problem, I would purchase a small Camera,/Receiver that sends a signal by radio frequencey they are available in Burgular alarm shops maybe Jaycar. The camera runs on small batteries. Mount the camera in the boot (on Bricks or wooden blocks) to check each top corner and the top of the boot. You can connect the receiver to a TV in the Van or even a VHS/DVD Recorder for more later viewing.
You may need to have a more powerfull light in the boot, would look at some kind of 12volt Fluro.
Your problem can be fixed, it just comes down to the effort.
415943
Reply By: lizard - Sunday, May 09, 2010 at 10:34
Is the boot lid double skinned ? Our Coromal had a crack in the outside double skin - which filled with rain & dripped into boot , solution was to drill small drain hole outside bottom lip ......
415945
Reply By: Member - Alan John C (WA) - Sunday, May 09, 2010 at 11:43
Hi Andy we have the same van and we had same problem we found the problem was with the width lights up top of van. The rubber surrounds do not seal addiquately and allow
water in, which finds its way down inside the external wall into the boot. I found after loosing a lens on a tree branch when I went to replace the lens the housing let go and whole assembly fell off so replaced with LED lights with new rubber seals and a little smear of silastic no more problems. I now have done this with all because like yourselves our van stored outside and I notice that the seals around the lights do not last so I hope this helps with your problem and to top it off no not all Genesis leak it is another dealer giving you the cold shoulder regards Alan.
415954
Reply By: Member - Kevin J (Sunshine Coa - Sunday, May 09, 2010 at 11:58
Andrew,
You have now joined the rather extensive group of caravan owners who have this problem of
water leaks in common. Be assured that the problem you have now is just
the tip of the iceberg.
"the dealer said that they all leak and that there was nothing that they could do"
Firstly the statement is partly true. A lot of vans do leak and not just at the boot. The major cause is incompetence on the part of the constructing personnel and total arrogance on the part of the manufacturers.
Secondly there is a lot that they can do.These leaks are most often caused through the lack of sealant in all those areas where a solid surface does not exist. Windows, airconditioners, vents and worst of all the lights. If the manufacturers would only look at their product with some pride in what they sell then they would be making sure that the job was done correctly in the first instance.
What will cause you a bigger headache will be the potential damage which can and does occur when the
water gets to the structural timbers and or the internal lining of your pride and joy.
Our van is just 4 years old and is currently in the
shop being rebuilt.
Water gained entry through defective - read non-existant - sealant around almost every break in the outer skin. Almost 30% of the timber frame has had to be replaced and the cost is going to be ??????.
No warrenty. Not insurable. The dealer is not interested and the manufacturer has so far refused to respond to correspondence. What next?
We have also written to the RVMAA but since this is an organisation set up by the manufacturers and run by a board comprised of manufacturers I doubt if we can expect much support from that front.
In my enquiries I have found that this is a very, very common situation and found in vans across the spectrum with some notable exceptions. Since I cannot name the "bad" brands I will not name the "good" ones.
My advice is: Hound the dealer until your van is TOTALLY resealed. Threaten them with anything short of violence. Used car salespeople are saints.
If you think that
water leaks are a minor problem please think again.
Kevin J
415959
Follow Up By: Cruiser .- Sunday, May 09, 2010 at 16:33
Kevin J,
My BIL has a Windsor thats 4 yrs old and he has the same problem in the front of the van.
He is currently pulling it apart to assess just what needs to be done.
Hopefully I will get some photo's tomorrow and will post them here for you to look at.
Cruiser
686084
Follow Up By: Cruiser .- Monday, May 10, 2010 at 17:58
This is the damage to my BIL 4yr old Windsor
Windsor Water Damage
Cruiser
686228
Reply By: Member - Teege (NSW) - Sunday, May 09, 2010 at 12:27
Andrew
Your van is not "of Merchantable Quality". I presume that Windsor is in fact a company. As also would be the dealer. That being the case, they are subject to the provisions of the Trade Practices Act.
TRADE PRACTICES ACT 1974 - SECT 74D
Actions in respect of goods of unmerchantable quality
(1) Where:
(a) a corporation, in trade or commerce, supplies goods manufactured by the corporation to another person who acquires the goods for re-supply;
(b) a person (whether or not the person who acquired the goods from the corporation) supplies the goods (otherwise than by way of sale by auction) to a consumer;
(c) the goods are not of merchantable quality; and
(d) the consumer or a person who acquires the goods from, or derives title to the goods through or under, the consumer suffers loss or damage by reason that the goods are not of merchantable quality;
the corporation is liable to compensate the consumer or that other person for the loss or damage and the consumer or that other person may recover the amount of the compensation by action against the corporation in a court of competent jurisdiction.
Tell the dealer you intend to take action against him and the supplier under the TPA. Dealers have hidden behind this defence of "they all leak....." for too long. If you pay good dollars for an item you expect to receive one which is fit for its purpose.
Have a look at the
ACCC website
My experience is that they will only play
the bluff so far. If they know you are fair dinkum they will usually
cave in. Yours is a new van and they have to ensure it is of "merchantable quality".
teege
415965
Follow Up By: Member - A J- Sunday, May 09, 2010 at 18:55
Andrew- I would be asking for my money to be refunded from the dealer - under the Australian Competition & Consumer Commission their web site states
"When can I ask for a refund?
You have a right to seek to seek a refund if the goods you bought :
- are faulty
- are unfit for their purpose ( they don't do what they are supposed to do)
- do not match the description or sample you were shown
- have defects that were not obvious or were not brought to you attention when you bought them."
A J
686108
Reply By: j100 - Monday, May 10, 2010 at 14:26
Often the rubber seal is the culprit
There needs to be a small gap in the rubber on the bottom on each side to allow the
water to drain away to theoutside of the van otherwise the
water builds up between the lid and its frame and will flow inside the boot especially if the boot is in the angled front part of the van
I speak from experience wiyh a leaking boot for some time until some one advised that there should be a small gap in the rubber
416124
Reply By: andy mitchell - Tuesday, May 11, 2010 at 08:05
thanks every one for you're very helpful reply's, i will get on to the dealer again due to the van still being under warranty
thanks again kindest regards
andrew
416223
