shift on the fly - holden rodeo 06 td auto
Submitted: Wednesday, May 12, 2010 at 17:16
petengail
have only had this rodeo for about 5 months no apparent problems. however last time we were away after towing the van out of reasonable sand, i thought the push button shift on the fly took a while to kick back to 2wd from 4wd. this afternoon i picked up management from her work and on a long stretch of straight road with only 3 traffic lights put it in 4wd - went into 4wd straight away. then after a few minutes put it back to 2wd, it took 3 klms for the flashing light on the dash to indicate that it was back in 2wd. does anyone have any advice on this please? cheers pete
Reply By: Patrol22 - Wednesday, May 12, 2010 at 17:22
Suggest you read your owner's manual Pete - shift on the fly into 4H works every time but getting out of 4WD may require you to select reverse and back up a metre or so....quaint feature of all part time 4WD vehicles....doesn't necessarily happen every time but will happen sometimes. I don't have a Rodeo by my D40 manual certainly talks about this as did my GU Patrol manual.
416421
Follow Up By: Patrol22 - Wednesday, May 12, 2010 at 17:32
.....also Pete....not a good idea to engage 4WD on a paved surface at any time let alone for several kms (straight road or not)....this again is talked about in your handbook.
686537
Follow Up By: Olsen's 4WD Tours and Training - Wednesday, May 12, 2010 at 17:39
Ditto all the above. I know we blokes do it as a last resort but do read the manual, it is even more important these days. 4wd should never be engaged on bitumen.
686538
Follow Up By: petengail - Wednesday, May 12, 2010 at 17:43
thanks for the prompt reply i shall take another look at the manual. I did read the manual, however from memory it said something like ... dont use constant (full time) 4wd on paved surface as it will give a lot of wear on the drive train. anyhow thanks for the input. appreciate it. cheers
686540
Follow Up By: Patrol22 - Wednesday, May 12, 2010 at 20:25
Pete constant or full time 4WD have a centre differential and these babies are designed to operate as the name suggest ie full time.....now if you lock the centre diff that is another story all together....and if you do this on paved surfaces stand by for some lightening of your wallet if the drive train winds up a little too far.
686573
Follow Up By: Olsen's 4WD Tours and Training - Wednesday, May 12, 2010 at 20:31
Petengail
All Rodeos I have seen from that year have selectable 2H, 4H, 4L, that is they are part time 4wd, not constant 4wd. But anyway, I'll let you check the manual. If it is part time 4wd as I suspect, then you should not engage 4wd on grippy surfaces like bitumen and concrete. This is because the front and rear axles will not turn at exactly the same revs (for many reasons) and since they are coupled together by the transfer case, if a wheel can not slip on the ground then something mechanical has to give- which it will eventually do in spectacular and expensive fashion.
- btw constant 4wd is a misnomer if ever there was one. No vehicle that actually has both axles driving 100% of the time could avoid the nasty scenario above. Constant 4WDs are not "hard coupled" in the transfer case, they have a centre differential that allows slip and thus are not truly constant 4wd at all.- unless you engage the centre diff lock. If you are keen to understand this better, I thoroughly recommend doing a search of your local area for a good 4wd training course.
Kind regards
David
686576
Follow Up By: fisho64 - Wednesday, May 12, 2010 at 21:24
David-going by that description of yours about constant 4wd-then there is no such thing as 2 wheel drive either.
Then even with centre diff lock engaged its not "4wd" as youve described unless it has 2 difflocks.
Its only really a description for ease and probably just complicates things for a beginner to describe it that way.
686588
Follow Up By: Olsen's 4WD Tours and Training - Wednesday, May 12, 2010 at 21:33
True but my point is that a full time 4wd does not have both axles driven 100% of the time, regardless of the number of
wheels driven, whereas a part time 4wd does have both axles driven when in "4wd". So the full time four wheel drive is less 4wd than the part time 4wd, unless the centre diff is locked in which case it is equal....go figure. Now if that doesn't confuse some, I'll eat my hat :-)
686590
Follow Up By: fisho64 - Thursday, May 13, 2010 at 13:41
yes :-)
but unless part time 4wd has difflocks, neither is it driving all
wheels at the same time, all the time!
Pedantic lesson finished on my part!
686654
Follow Up By: Olsen's 4WD Tours and Training - Thursday, May 13, 2010 at 18:28
Yes but being even more of a pedant, the full time 4wd's worst performance "in constant 4wd" is one wheel drive whereas the part time 4wd's worst performance is 2wd :-)
686687
Follow Up By: Olsen's 4WD Tours and Training - Thursday, May 13, 2010 at 18:30
with 4wd engaged - i meant to finish. Yes pedantic for sure but many a Prado owner have I assisted who was bogged, and told me incredulously, he couldn't understand why he needed to lock the centre diff, as "it is full time 4wd" :-)
686688
Follow Up By: fisho64 - Thursday, May 13, 2010 at 18:35
"full time 4wd's worst performance "in constant 4wd" is one wheel drive whereas the part time 4wd's worst performance is 2wd :-)"
:-) HOWEVER-if your can has only 1 wheel on the ground-you are in the s++t!
There are always going to be 2
wheels on the ground at least and whether part time or full time you are still clucked without a difflock in that situation!
gotta laugh though-I enjoy reading your posts, as they are among the more informative!
686690
Follow Up By: Olsen's 4WD Tours and Training - Thursday, May 13, 2010 at 18:37
Thanks fisho....just having a bit of fun and hoping it causes a few to think and investigate. All in good fun
David
686691
Follow Up By: Member - Christopher P (NSW) - Friday, May 14, 2010 at 01:10
HI Guys, i have seen a 4wd that was left in 4wd and had just come off a 110klm zone on the sunshine coast, i was only 18, and it scared tehcrap out of me, front
wheels spinning in reverse, back
wheels pushing forward.
so please check and double check you haven't locked anything up incorrectly.
Oh a word of wisdom, READ THE MANUAL.
I do and get a lot of praise from the other HALF as she doesn't bother, not when she has me who has read the manual,.
686744
Reply By: Sand Man (SA) - Wednesday, May 12, 2010 at 20:10
Pete,
Do the "test" again and when selecting 2WD, lift your foot off the accelerator for a bit, then observe the indicator light on the dash.
Bill.
416452
Follow Up By: Tonyfish#58 - Wednesday, May 12, 2010 at 20:38
Sometimes as
well as the back off on power, it takes a push of the clutch as
Its all in the owners manual - Wait until you start doing the low range work - you will have fun getting it in and out if you do not do as the manual says.
To go in to low 4, Stop and out of gear with foot off clutch before selecting. To get out Stop, out of gear and push button, if it still flashes quickly push the button again, when flashing slowly reverse the car a bit.
Its all fun until you get the hang of it. Cheers Tony
686578
Follow Up By: Sand Man (SA) - Thursday, May 13, 2010 at 07:16
You may
well be right Tony. I have an auto so no "clutch" to think about.
Bill.
686612
Reply By: Patrol22 - Wednesday, May 12, 2010 at 20:29
Pete you might like to read the really good and easy to understand information at
THIS SITE - should help you get a reasonable understanding of how a 4WD works (in all its guises).
416461
Reply By: Alloy c/t - Wednesday, May 12, 2010 at 21:11
You should only try to engage / disengage 4H under 80klm hr with the front
wheels dead straight ,lift the R/Foot for a second or two after the light starts to flash ,, If all else fails you can reset the 4x4 electronic system by ,,,
When stopped , IGN off - Push and hold in all 3 Buttons - Turn IGN to on BUT do NOT start vehicle - continue to hold all 3 buttons 'in' for 30 seconds , all dash lights will extinguish as per normal EXCEPT for the 4x4 light which will continue to flash , ----- release all 3 buttons and turn IGN to off , ---- Start vehicle as per normal , Select 2H or 4H as required .
416470
Reply By: fisho64 - Wednesday, May 12, 2010 at 21:18
The reason why it wouldnt disengage would likely be cos the drive train was wound up and under strain. Needs the load of it to disengage.
As mentioned above-DONT put it in 4wd on pavement!
416472
