Monday, May 17, 2010 at 21:21
you are not stuck to 1/250 .. if you are NIKON biased you should know
that there are other solutions...
one example is for both Canon and Nikon you can use high speed sync on
the speedlights, which reduces the effective output but it still does sync
and you can also use manual mode with external flashes like Elinchrome with very short flash durations. The D80 actually could sync way beyond 1/200 because
of the electronic shutter, but it was only a 6MP.
I have a 1DS-Mark II (a real oldie nowadays) and it does sync at 1/8000 with
two or three 580EX in FP mode ... 17 Megapixel and one can buy these at 2k
or so. Still brilliant and beats most Nikons before the D3X as far as image quality
is concerned.
Usually such applications are done with laser sensors and infrared triggers.
good luck
gmd
687170
