03 Ford Explorer
Submitted: Sunday, May 23, 2010 at 14:08
ThreadID: 78698 Views:3382 Replies:4 FollowUps:1
Hi, I just bought an 03 Ford Explorer, and I'm wondering what their performance is like and if there are any major things wrong with them. I heard there were issues with the earlier models, but this one looks ok. Its an automatic (eugh) but I bought it at auction (hail damaged) and it was pre-approved for licensing. I'm not intending to do any extreme 4WDing in it, though I do intend to take it up north in July if it all works out.
Any help greatly appreciated, this is an upgrade for my 1990 Nissan Navara because the gearbox is on its way out and its not really economical for me to replace it.
Reply By: Captain_Miriam - Sunday, May 23, 2010 at 14:23
Also, as I believe there are no stupid questions, how do I tell if the car is running on dual fuel, rather than just gas with the petrol disconnected? I didn't realise until we poked around a bit that there is a gas port at the back, and it has a conversion sticker under the bonnet. I really want to be able to run it on both, as gas can be hard to get in remote areas (read impossible).
AnswerID: 417795
Follow Up By: dbish - Sunday, May 23, 2010 at 17:49
Hi there, I personaly wouldnt put gas on a Ford Explorer as they are not recomended for gas conversion. Also been known to bleep ter the plastic inlet manifold, with gas backfire. Daryl
FollowupID: 687902
Reply By: Member - Toyocrusa (NSW) - Sunday, May 23, 2010 at 16:53
Hi. Not wanting to rain on your new purchase but they are nicknamed "Ford Exploder" That said some people have had a good run out of them so it could be a lucky dip. In regards to your gas question. The engine should start on petrol and transfer to gas automatically within a short period of the engine starting. You would need to make sure there is at least quarter of a tank of petrol. There should also be a 2 or 3 way switch some where handy on the dash which can manually change from petrol to gas and vice versa. Normally it will have a petrol bowser symbol on it and with the switch towards this symbol it should be running on petrol. ( There are some systems that have a light instead of a symbol and a button instead of a switch) The best idea is to make sure you have both gas and petrol. Start and run the engine in park at about 1500 rpm and make sure it runs with the switch in both positions. Once you have achieved that it is then a matter of working out which position is for gas and the other for petrol. ( a three way switch has both off in the centre) Good luck with your purchase and I hope it stays reliable for you. Bob.
AnswerID: 417824
Reply By: Kiwis Ross & Cushla- Sunday, May 23, 2010 at 20:28
Good on you.We have a 2002 4 ltr V6 on petrol only towing a Jayco Westport,18ft.We have done over 30000 km in last 9 months,only major problem was collapsed rear wheel bearing but this was fixed [did both] in Darwin,no problem.Uses a bit of petrol when towing but performs ok,have only used high and low range a couple of times.Very comfortable and well appointed.Had some hassels when matching up caravan to car as the Explorer is quite high and we had to get a low hitch from Hayman Reese,all worked out ok. Now..........if you listen to all the Toyota and Nissan owners you would expect to see Explorers littering the road all over Australia.....well I have met more Toyota and Nissan owners with cars disabled during our travels than Explorers.Also dont be taken in by the diesel verses pertol argument......petrol still works out cheaper taking into account purchase price of vehicle etc.Enjoy your Explorer,we are.
AnswerID: 417874
Reply By: Member - Roger B (VIC) - Sunday, May 23, 2010 at 22:25
We've had a 2000 Explore since new and it hasn't missed a beat. Been round the block more than once,went out to Steep Point with ease, and towied our campervan along the GRR, and now a Coromal pop top to NQ every Winter.with a few local trips in between. Got nearly 200,000kms. on the clock. Sure it likes a drink, but it weighs nearly 2 Tonne itself, plus about 1.5 Tonne of van. and all the goodies we all carry on board. Enjoy your Explorer. Cheers.
Roger B...
AnswerID: 417889
