oil type for jackaroo 99 diesel
Submitted: Friday, May 28, 2010 at 21:13
ThreadID: 78860 Views:5258 Replies:5 FollowUps:5
Related Pages
Hi Guys:Please tell me if oil 10 W 30 is the right iol to top up my Jackaroo diesel 3.0 1999.
thanks
Reply By: Madfisher - Friday, May 28, 2010 at 22:25
I know if you put the wrong oil in it will not start. Try the guys at Australia4wd forum then the isuzu section, then their is a sub section for the 4jxi 3lt Diesel.
Cheers Pete
AnswerID: 418604
Follow Up By: caramelos - Sunday, May 30, 2010 at 10:29
thanks Pete
FollowupID: 688878
Reply By: MEMBER - Darian, SA - Saturday, May 29, 2010 at 09:00
I had one for 8 years ....... 10W-40 for mild conditions should be quite ok - you need to go thinner for cold climates - specs go down as far as as 5W and 0W-30 for snow etc. Cold oil temperature governs how well they start - crazy but true.
The later models were shipped with two batteries to try and get them running in cold condition starts.
AnswerID: 418632
Follow Up By: caramelos - Saturday, May 29, 2010 at 11:01
thank you kindly
FollowupID: 688754
Reply By: outsider - Saturday, May 29, 2010 at 10:30
I've been using castrol magnatec 10-40 in mine, that is what holden recommends for the 4jx1.
AnswerID: 418639
Follow Up By: caramelos - Saturday, May 29, 2010 at 11:02
thank you so much
FollowupID: 688755
Reply By: Kirko2 - Saturday, May 29, 2010 at 17:29
Hi Caramelos,
we also have a 99 jack t/d and we use the 5w40 the penrite HPR5 i think it is. Anything higher than the 5W causes starting problems in the cold. I am from Tas and last yearr was in Broome and had the car serviced and they put the wrong oil in and it became hard to start by the time we got to Karijini so we had to change the oil to a 5W. As some one has said there is a huge amount on the jackeroo forum specifically on this issue
Kirko2
AnswerID: 418669
Follow Up By: caramelos - Sunday, May 30, 2010 at 10:30
Thanks kirk02
FollowupID: 688879
Reply By: anglepole - Sunday, May 30, 2010 at 09:30
I owned one of these Jackaroos and found it a very capable and joy to drive vehicle.
The oil I used was BP VANELLUS C6 GLOBAL PLUS and found it started down to -5c. I wrote to Holden and even got a letter back endorsing the use of this oil.
Cheers and enjoy
AnswerID: 418737
Follow Up By: caramelos - Sunday, May 30, 2010 at 10:31
Thanks Anglepole!!!
FollowupID: 688880
