Roof or side mounted A/Conditioning
Submitted: Sunday, May 30, 2010 at 11:52
OREJAP
Hi all. I know that the types of A/cond fitted to vans can vary & it depends on size of the van & the HP of the A/cond, but is a side wall unit better or as good as roof mounted. Is it more beneficial to have a side mount rather than a roof especially considering the height factor? Is there a rule of "Thumb" for calculating the amount of HP needed for a particular size van ie..16'6 = 2.0hp or a 19' = 3.0? for interest consider a FV not a PT. Do manufacturers put smaller units in their vans to cut down on cost like some do with insulation? Members
views would be appreciated.
Reply By: Member - Graham H (QLD) - Sunday, May 30, 2010 at 13:06
Well have been parked beside a side mounted one and it was noisy as.
We are putting a 3hp in a 109sqm apartment so would be an overkill in a van.
Do a search on Dometic, Air Command, Carrier etc and you will see the sizes Most roof mounts seem to be the same capacity and you just turn the up or down to suit.
418770
Reply By: JAZZY - Sunday, May 30, 2010 at 15:50
We have a side mounted aircon and no problems at all. Not noisy from the inside hehe.
Anyway, we had heard that roof tops ones were not ideal for the following reasons:
1. Roofs may sag
2. Adds height to the van (especially if
parking under trees in
park)
Havent seen a sagging roof but just what I have read in other forums.
418787
Reply By: Faulic_McVitte - Sunday, May 30, 2010 at 16:21
All caravan air cons are dogs. Noisy, expensive and rubbish.
Fit major brand domestic inverter air con Mitsubishi, LG, Daiken etc.
Inverter air cons are quiet inside and out. Can power from 1kva gennie.
418790
Follow Up By: Rockape - Sunday, May 30, 2010 at 19:30
Yep!!!!!!! agree, they are rubbish, as you said domestic inverter splits are the go.
688955
Reply By: Gazal Champion - Sunday, May 30, 2010 at 16:25
Hi Orejap,
Roof mounted units place a fair amount of stress on a roof unless the van has been manufactured to accommodate it. On my Gazal Champion the airconditioner has been mounted on what is known as a 'H' bar which is an steel frame made to for the job and is available from most caravan spare outlets. Camec have them.
These H bars spread the load of the airco unit to the side walls and take the bounce out of the roof mounted units. A much better idea in my opinion.
But that is just my opinion, for what it is worth.
There is a trend now to mount split systems in vans and at face value it seems a good idea.
Cheers, Bruce.
418792
Follow Up By: Member - Graham H (QLD) - Sunday, May 30, 2010 at 16:32
Whilst it seems people think the roofs arent strong enough to mount them on what about the strength of the walls to hang the head of a split system on.
Lots of van walls stay up only because of the sandwich effect of the cladding and its often the windows and the furniture that give it rigidity and strength.
I would be reluctant to hang too much weight where the wall wasnt designed for it.
688916
