Generator Running Time Between Oil Changes
Submitted: Thursday, Jun 03, 2010 at 23:29
ThreadID: 79044 Views:4654 Replies:4 FollowUps:7
Hi All
I have always been bad at estimating the running time of my generator, in regard to changing the oil. I have come across a cheap hour meter, under $25 from ebay. I have just fitted it to my gennie, and seems to work fine. It has an lcd readout, does not need a battery. A wire runs from the spark plug lead, where it is wrapped around 5 times and secured with a couple of zip ties, to a slot in the back of the unit. The unit it's self, attaches by two screws. Just thought I would mention it to others that may be interested.
Hour Meter
Image Could Not Be Found
Neil
Reply By: Member - Fred B (NT) - Friday, Jun 04, 2010 at 00:21
Hi Neil,
had thought about buying one in the past, but now that I see it mounted on your genset, I have ordered one too.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 419464
Reply By: Ozhumvee - Friday, Jun 04, 2010 at 07:39
You can also get one from Tiny Tach which will give you the engine RPM as well as service intervals.
AnswerID: 419478
Follow Up By: Member - mazcan - Friday, Jun 04, 2010 at 09:53
hi ozhumvee
do you have a link to or for tiny tach
thanks
FollowupID: 689670
Follow Up By: Ozhumvee - Friday, Jun 04, 2010 at 10:10
www.tinytach.com
I've actually got a diesel one on the Humvee which has worked flawlessly for 5 years now.
Also got one on the Yamaha 1kva gennie which is the one you would be after.
There is an Aussie distributor but the last time i looked they wanted silly money for them and it was quicker, cheaper and easier to buy online from the tinytach website which is what I did for both mine. There is a tab for international buyers.
Also keep and eye on ebay (.com not au) as occasionally there is a seller that sells them there too.
FollowupID: 689673
Follow Up By: Member - mazcan - Friday, Jun 04, 2010 at 11:11
hi ozhumvee
thanks for imfo
does the diesel type tacho take it's feed from the alternator????or ????
FollowupID: 689691
Follow Up By: Ozhumvee - Friday, Jun 04, 2010 at 11:26
No you just clamp a wire to one of the injector lines, very simple and has been very reliable, revs displayed in digital form and has two service intervals also keeps max RPM in memory.
FollowupID: 689694
Follow Up By: Member - mazcan - Friday, Jun 04, 2010 at 11:46
hi and thanks
by that --- injector lines ------meaning steel pipe
or electrical cable ?
as in high pressure system ???
thanks just trying toclarifying
FollowupID: 689696
Follow Up By: Ozhumvee - Friday, Jun 04, 2010 at 12:57
Just clamped on the steel injector pipes, it senses the pulse of diesel from the injection pump.
Have a look at the website it tells you all about it.
FollowupID: 689704
Follow Up By: Member - res.q.guy (Vic.) - Friday, Jun 04, 2010 at 13:25
Hi Peter
Yes, I did come across the Tiny Tech, but I have no need in this application, to know the RPM, just hours used.
Neil
FollowupID: 689707
Reply By: robertbruce - Friday, Jun 04, 2010 at 11:31
i replace my oil every three tanks of fuel - the manual says evry 20 hours, which is every two tanks of fuel but i found that a bit excessive...
my EF1000is has over 8000 hrs on it and still going strong...
AnswerID: 419504
Reply By: FrankJ - Friday, Jun 04, 2010 at 16:46
It is one of the reason why I always go to mechanics with expertise. There may be so a lot you are able to do yourself on a automobile that will save you hundreds. In the event you take your vehicle little by litter it genuinely isn't as complex as it seems. There exists something not functioning properly if your examine motor light is on. Your mass air flow censor is probably not working correctly if this light is on. If your mass air flow censor is off, your vehicle will get less gas mileage and could hurt your motor. Simply cleaning it can make a world of difference, but occasionally replacing it is the key. Changing your mass air flow censor just isn't tough at all. If you can adjust a tire you are able to transform this.
AnswerID: 419546
