Speed sensor wire
Submitted: Friday, Jun 04, 2010 at 15:53
Spectrum
Hi All,
I am fitting a Terratrip to my '99 GU Patrol and need to find out which wire and what colour and where I would find the speed sensor wire.
Thanks in advance
Trev
Reply By: fugwurgin - Friday, Jun 04, 2010 at 17:22
hi, what motor?
419552
Follow Up By: Spectrum - Friday, Jun 04, 2010 at 22:55
2.8 litre turbo diesel
689773
Reply By: Member - Rob S (NSW) - Friday, Jun 04, 2010 at 17:24
The speed sensor it self is located on the transfercase out put shaft housing.
It will have two wires on it. you could make a connection there.
Or trace the coloured wire's back to the dash.
Or try here
down load a work
shop manual an look at the wiring diagram
http://www.patrol4x4.com/forum/index.php
419553
Reply By: CABROLET - Friday, Jun 04, 2010 at 19:22
Hi Trev
You have two types of sensor you can use. One is the interface electronic unit that is in the wiring from the speedo or you can use the jap gear box probe unit that attaches to the speedo drive at the gearbox. I have the wireing diagrams for both
419573
Reply By: Spectrum - Monday, Jun 07, 2010 at 06:20
Thanks all,
I now have it working through the electronic interface.
Trev
419869
